Thread: Plumbing question, need to seal off spa jets for press. test
    Hello again, I'm working on my pressure test for my plumbing inspection. I sealed off the returns with 1 1/2 threaded plugs. They were loose but a bunch of teflon tape seems to seal them.
    The spa jets all leak, there is a little tab on every one that keeps them from completely sealing closed, I assume it is there for a reason?
    These jets appear to be a 1 3/4 diameter or something odd.
    Does anyone have any tricks for sealing off something like this?
    My Plan B is to isolate the spa lines with a valve for the test and leave them uncovered for the inspection.
    Do you think the inspector would go for that?
    BTW, I can pressurize everything to 20 PSI even with the leaking jets, I just have to keep the supply water on.
    Thanks, John.
    "Experience is what you get, just after you needed it."
    Owner DIY build, steel/liner kit, 18x36 Deer Creek, sport depth, approx 17,500 gal,
    Aqua Plus SWG, 1 1/2 hp, 2 speed, 300# sand filter and twin Color logic 4.0s, MX-8 Cleaner.
    My DIY Pool Build
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Plumbing question, need to seal off spa jets for press.
    I'd think a test plug would do it. They come in many sizes.
    hi,
    I really have no experience what so evr on this topic but I found this site this afternoon and thought it may give you an idea.
    http://www.leaktools.com/products/press ... ing_plugs/
    good luck
    Cement 12'x30', in the neighborhood of 50 years old. Restored, 1.5"plumbing, 1hp super pump 2, Hayward swim clear cartridge filter, Summit2.5t heater,Hayward SWG t-9 cell, Nexxus Blanco lights, pentair bermuda gunite skimmer.
    Had a 2" test plug that would not fit into the spa hole. The outer flange on the plug was too big to go in far enough (about 2 inches deep).
    It would require some of those custom plugs like brownsburg suggested.
    My plug is a Home Depot Oatay plug just like JohnT showed except luckily it is plastic.
    I modified it with a band saw to cut the flange down to under 2".
    Works great, now I need to find and modify just 11 more.
    I should buy stock in Home Depot.
    Thanks guys,
    John
    My DIY Pool Build
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Quote Originally Posted by rv4hess
    Thanks guys,
    John
    Lowes for me, its right around the corner. I cant tell you how many $1000 weekends I have spent there. lol.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
