Results 1 to 7 of 7
Thread: Valvel Fittings/Tools
    Happy Sunday Folks, I got my SWG yesterday and I'm trying to install it. Having a plumbing problem though.
    Attached is a picture of my dilemma. What tool would you use to loosen the fitting circled in red. I'm hoping that the grey pipe to the right of the circle (the part with the "return" label on it) is not part of the valve, as it doesn't look like they've left enough pipe there (white) for me to add a new coupler to.
    Any ideas?
    Thanks, Jim.
    In ground Pool, 13,000 gallons, Cartridge filter (big), Single pump, Hayward Goldline Aqua Rite
    Central Florida
    Miller Lite
    Tony Stewart
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,966
    Re: Valvel Fittings/Tools
    Big channel locks or a strap wrench.
    If you have to go buy one, get the strap wrench, less likely to dig into the plastic or tear chunks off the coupler.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,552
    You can also see if an old oil filter wrench (metal band) will fit around it. Might want to wrap a thin rag around the union first.
    I was hoping to be able to get the fitting undone without having to cut the pipe to the right of the gray pipe. With no open end on pipe as it is now, I can't get any type of oil filter or strap wrench around it.
    Central Florida
    Miller Lite
    Tony Stewart
    Richard320's Avatar
    Jan 2010
    18,966
    Quote Originally Posted by Jimbolo
    Yes, you can!
    [youtube:13gkzbgz]K5AyJEQ0f-o[/youtube:13gkzbgz]
    Watch at about 1:30, the straps wraps around then gets attached to the handle.
    Edit: hmm, youtube embed didn't work. Just copy n paste the URL, then.
    Fixed. Just use the movie code #, not the rest of the URL, with the youtube tag. JasonLion
    Thanks Richard, Went ahead with the hack saw method and used an oil filter wrench. I figured I was going to have to cut it anyway. Too little room there between the valve sleeve and the table feeder to be able to cut it and get a union on it. Now I'm on a mission to find a Praher nut and sleeve.
    I appreciate the quick replies!
    Jim.
    Central Florida
    Miller Lite
    Tony Stewart
    Mar 2011
    Scottsdale, AZ
    406
    This is what I use alot. One of the handiest tools I have ever purchased.
    Its a locknut wrench, sells for about $5.00 at Home Depot.
    http://plumbing.hardwarestore.com/52...h--622622.aspx
