Thread: Tear on pool cover
    Tear on pool cover
    I have an in-ground pool, 18' by 36', with an automatic pool cover (the brand is Pool Covers).
    The problem is that earlier today the cover was opening unevenly, and at one point the side that was not opening as much as the other tore from the material that is attached to the rope, on the corner.
    I was able to straighten out the bar the lies across the pool, and at least now it opens and closes evenly.
    How do I go about fixing the tear? It seems what failed isn't the cover material or the material that is attached to the rope, just the thread.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Tear on pool cover
    Welcome to TFP!!
    I'd call the manufacturer, or look them up on line, to see if they have better advice than mine
    I may be able to come up with something if you can post a pic of the damage.
    Also, try to figure out why the cover is reeling unevenly.
    Luv& Luk
    -Ted
    Mar 2011
    441
    Quote Originally Posted by apoolowner
    Typically the only way to repair this is to sew it back up.,
    20X40 30,000 gallon gunite pool
