Thread: Help my reversed pool pump motor.
    I have been out this morning getting the pool ready to start up and when i plug my pump into the outlet it works and sounds fine but it is drawing water in from the discharge and blowing it out of the skimmer like its in reverse or something. The pump is a 2 hp 115 volt non reversible motor with regular above ground pool sand filter. I tried to reverse the motor by switching the white and black wires but like it says it is non reversible. whats wrong and how do i fix it?
    18x36 Vinyl In-ground w/roman ends 27,400G, Hayward 3/4hp with 300# sand filter. Hayward heat pump heater
    Pool School
    Pool Calculator
    Test Kits
    Re: Help my reversed pool pump motor.
    Welcome to TFP!
    I'm not sure how you could get a pump to pump backwards even if you wanted to.
    Are you sure you don't just have the hoses switched between the pump/filter and the pool?
    not really any way to switch the hoses the one that runs from the sand filter is too short to run to the other hole on the pump and the other hoses will only go the one way.
    Pool School
    Pool Calculator
    Test Kits
    should the hose from the skimmer go in the pump itself of into the top of the filter?
    this may be where i went wrong.
    Pool School
    Pool Calculator
    Test Kits
    Mar 2011
    Scottsdale, AZ
    406
    It should go skimmer to the pump, top of pump to filter, and then filter to pool returns.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,396
    Yes, the hose from the skimmer goes into the front of the pump.
    Love TFP? Become a
    TFP Supporter!
