Thread: Plumbing suggestion please
    I want to install the intellichlor IC40, and I am hoping to get some suggestions on plumbing.
    The manual recommend 3ft distance from the heater, and 12 - 18 inches of straight pipe before the intellichlor. Please see the picture for my plumbing situation. A is 16 inches. B is 11 inches. C is 27 inches.
    I was thinking I can add another 10 inches at the end of B to get the 3 ft. But then I would need a 180 degree to go back, and then 90 degree down to the return pipe. Doesn't seem very effective that way.
    What is the most effective way to install the intellichlor based on my setup?
    Thanks!
    18'x40' (est. 20K gal) Kidney shape pool // Pentair Intelliflo VS-AU // Pentair Suntouch // Raypak RP2100 Digital // 48sqft DE filter // Stenner 85MHP17 peristaltic pump // Dolphin Deluxe 4.
    Re: Plumbing suggestion please
    I would go up perhaps 12" around where the A is in the photo, to level, to down straight towards C, with the SWG mounted vertically a little above where the C appears on the photo. That only adds one 90 to the pipe and should easily accommodate your clearance requirements. You should double check the heater manual to see if it calls for any special plumbing restrictions after the outlet, and you may need to slightly adjust things from what I said to get everything to come out exactly right, but the basic approach should work.
    Humm... never thought about going up.
    Thanks!
