Thread: SWG pool how much stabilizer is typically used per season?
    Oct 2010
    Eastern TN
    172
    Just starting with new pool and pb is starting chemicals. I'm planning ahead, how much stabilizer can I expect to use per season? Do I need to stock up now?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    30,426
    Re: SWG pool how much stabilizer is typically used per seaso
    Are you asking for the starting ppm or how much will be consumed?
    Starting ppm should be 60-80.
    I wouldn't stock any as it is not a consumable item and will only get lower in your pool through refilling and rainwater. You may have to add a little more once or twice this season.
    Oct 2010
    Eastern TN
    172
    That answers my question. I was wondering about amount needed for replacement.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    I usually keep a small jug of dichlor on hand to raise CYA. I'll shut off the SWG for a few days and use the dichlor for chlorine until I get CYA back where I want it.
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
