Thread: Polaris PB-4 bearings failing, repair or replace
    Aug 2010
    Lake Jackson, TX
    130
    My booster pump motor bearings are failing. Does anyone have experience replacing the bearings. The pump seals are leaking also so I am l looking at a new seals and bearings vs a new pump. Where can I get bearings? Not sure of the age of the pump, I'm leaning toward new since this one is looking rough and the inside of the pump has some corrosion, pitting. What brands are worth looking at?
    Thanks.
    25000 gal IG gunite plaster. Built in spa, built 1984.
    48 SF Hayward DE-4800 filter
    1 hp Hayward super pump
    3/4 hp Polaris PB-4 booster pump, Polaris 380
    Taylor K-2006 test kit
    South Central NJ
    3,192
    Re: Polaris PB-4 bearings failing, repair or replace
    Replace the motor and seal set. Changing the bearings and seal set on these isn't worth the effort, IMHO.
    Scott
    Owner of - PoolGuyNJ LLC
    22,548
    I agree with Scott, except that if the pump is very old I'd just look at replacing the entire pump.
