Thread: Location of salt cell (IC60)
    Oct 2010
    Friendswood, TX (near Houston)
    65
    We are in the start-up process and have not added salt to the system yet.
    While reading all the different manuals, I noticed that Pentair says "ALWAYS install the IC60 AFTER the filter and heater"
    I can certainly understand that the salt cell should be protected from dirt etc so after the filter is a must but what is the concern about not having it after the heater?
    Any thoughts?
    22000 gallon IGP, 820 sqft, SWG - IC60, infinity edge spa, Pentair Quad DE 100, 3 x Pentair Intelliflow 4x160 pumps (one for circulation + one for spa + one for sheer descents), spa with 8 jets + 4 leg jets, air blower, Pentair EasyTouch 8 remote, Pentair Intellibrites LED (white) - 2 in pool and 1 in spa, Pentair Master Temp 400,000 btu heater, 4 sheer descents (2x2', 2x6'), limestone coping and decking, Pebblesheen Prism Blue
    Useful links:
    Pool Chemistry
    Chlorine reactions
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: Location of salt cell (IC60)
    Not an expert here, but my thought is that you are not protecting the salt cell but the equipment that comes after it. The water coming out of the salt cell is not balanced. It is high in pH and chlorine and could damage the heater over time. At least damage it more so than if it were balanced.
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    It's worse than that. SWG cells produce hydrogen gas, which could build up in the heater causing poor thermal transfer to the water, overheating, and potentially an explosion.
    Oct 2010
    65
    Good to know. You definitely want to make sure they are in the right order, I guess......
    Useful links:
    Pool Chemistry
    Chlorine reactions
