Results 1 to 8 of 8
Thread: Liner type ?
    Liner type ?
    I just picked up an 18 foot ABG poolsteel sided
    . The guy told me it was 16' but when i layed out the track it was 18.he also said i need a over lap liner. Im not sure what kind i need. I dont have a name of the pool either. All i know is it has the same track on the bottom as the top edge. I found this out as i was laying all for the bottom lol .
    ps ya im a newbie lol
    any help would be appreciated
    18' x 52" Intex steel frame pool
    1500 gph pool pump
    Kingston Ontario Canada
    22,544
    Re: Liner type ?
    Overlap liner denotes how the liner fits over the top rail and is a pretty common style. It just folds over the top of the pool wall like a garbage bag over the top of the garbage can. Just go to your local pool store or search the internet for overlap liners and you'll find plenty.
    Re: Liner type ?
    Ya i did a bit of looking around on the net but found it hard to find. Does it sound like this is the liner i need ? SOunds like i need to lay the track then the walls then liner , put the top track on, then the verticals then the coping Then add water and cut out the skimmer and a way we go ....lol Sound about right?
    1500 gph pool pump
    22,544
    Re: Liner type ?
    Here's a link with the sequence. This is an oval pool but the process is real close. The pictures at the end are worth a lot.
    Re: Liner type ?
    that looks like the same set up as mine. What type of liner is that? Can I use either type of liner?
    1500 gph pool pump
    22,544
    Re: Liner type ?
    If your pool is an overlap type then you'll have to have an overlap liner unless you want to buy new top liner track which I wouldn't recommend.
    Re: Liner type ?
    thats the thing ! I am not sure what type of liner i need? How can i tell? The guy I purchased it from said it was an overlap type but how do i know thats what i need before i purchase it ?
    1500 gph pool pump
    dremin2flyhi's Avatar
    Jun 2010
    Darlington, SC
    121
    Re: Liner type ?
    There are normally 3 types....
    Overlap-- it is pulled and stretched over the wall and then a plastic strip (coping)is placed over the top about 1/2 " to 3/4" then the top rail goes on..
    J-hook or Unibead-- the is as it implies--this liner has a special edge that can be hung on the top of the wall and then no coping strip is needed --the liner is thick enough to be compressed when the top rail is placed on the wall .. This liner can also be used in a Beaded configuration also-- by removing the Part of the J- and then placing in the beaded receivers under the top rail.
    Beaded--- a more "precise" fit liner that has a special coping piece that fits under the rail the liner fits in..
    I prefer the J-hook-Unibead style--- easier to install and get wrinkles out .
    Make sure to get the right diameter for the pool and take special note of your wall height -- this will make a difference...
    24' x52" Sharkline Venture (May 2016) ABG (13,500)
    Hayward S180T15932S --Sand filter/ Flo-Matrix pump pack
    Aquatrol-RJ SWG-- Nitelighter NLMC
    Dolphin E10
    Duraspa G2- Premium hot tub --Rotomold style
