Thread: What do you do first raise PH or TA?
    Up and running here are my numbers
    FC 14.5
    CC 0
    PH 7.2
    TA 60
    CH 120
    CYA 50
    Temp 68
    Been bringing the water up to level today, clean a little cloudy. Have been adding bleach the last few days as it was getting warmer and we needed to fix some leaking pipes. What do I do next raise the TA or the PH 1st? I think I need to raise the TA because the baking soda will also raise the PH is that correct? Do I need to do any adjustments to other numbers? Second year with TFP opened to a clear pool no CC so far. Do I need to bring to shock level with 0 CC's?
    16X32 Rectangular In Ground Built 1998, New Vinyl liner and Motor 8/2012, 19,000, Hayward Sand Filter, Hayward Super Pump,PoolPilot DIG-220 SWG, 2 Skimmers, Main Drain, Clean Machine Robot, Full Sun, Bleach, TFTest Kit
    Central, VA
    22,543
    Re: What do you do first raise PH or TA?
    Since your pH is technically ok I'd raise the TA first but only to about 80.
    thanks I don't need to doing any other adjustments right?
    Central, VA
    Just raise the TA a little. You can leave the PH where it is. The PH will most likely drift up slowly, and anything 7.2 or higher is fine to swim in. If PH shows any sign of going down, then raise it.
