Results 1 to 7 of 7
Thread: Pressure Gauge Replacement
    Apr 2011
    Somewhere on the Emerald Coast
    156
    Is there any specific procedure to replacing the pressure gauge, like draining the filter, etc.?
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    Re: Pressure Gauge Replacement
    Nothing special is required. Just turn off the pump, remove the old gauge, wrap the threads on the new gauge with a couple of turns of teflon tape, and screw it in.
    Apr 2011
    156
    Don't I need to drain the filter? Some generic "How To" site said something like opening the airbleeder then the drain valve. I didn't see any such critter on mine (drain valve).
    If the gauge is on top of the filter then there is no need to drain the filter. If the gauge is on the multi-port valve on the side of the filter then draining the filter is a probably a good idea, though not essential. The essential thing is that the filter not be pressurized. Simply turning off the pump should be enough to insure that.
    Apr 2011
    156
    Gauge is on the side of the multi-port valve which is on top of the filter. I think I should just shut it off, open the airbleeder to relieve the pressure then take it off. What do you think?
    Sounds good.
    Apr 2011
    156
    Thanks for the input !! I appreciate it!!
