Thread: How badly does a 1.5" heater ruin flow in 2" plumbed pool?
    Oct 2010
    Eastern TN
    172
    Still considering all angles of adding a heat siphon to my pool. The internal plumbing in the heat pump is smaller than the rest of my system. This will affect flow but what does it translate to in real world use? How much work/electricity will it take to run my pump? Is this a significant consideration or not?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Re: How badly does a 1.5" heater ruin flow in 2" plumbed poo
    The added flow resistance of a heater is right on the edge of insignificant. In some pools with very efficient plumbing it is enough to be somewhat significant, while in most pools it doesn't make a significant difference. If your electricity is $0.40+ per kwh and the rest of your plumbing was designed for efficiency, you might want to think about installing a heater bypass. Otherwise, I wouldn't worry about it.
    Oct 2010
    Eastern TN
    172
    Thanks
