Results 1 to 19 of 19
Thread: Liquidator Question
    Jul 2010
    Central Illinois
    40
    Liquidator Question
    It's reading bt 0 and 1 on the flow meter with the valve open all the way. I must be doing something wrong, but I can't figure it out. Been tinkering with it all morning and moved it around to different spots, but I cannot get it the flow any better. Suggestions???
    18' x 54" Round AGP, Hayward pump/Cartridge Filter, 8 Gallon Liquidator, and TF-Test
    Re: Liquidator Question
    Do you have a two speed pump, or a variable speed pump? The Liquidator has lower flow rates when then pump is on a low speed. Also what is your filter pressure, and where do you have the Liquidator feed and return hoses connected?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    If your inlet and outlet hose connections on the Liquidator contaIner are ABOVE the pool water level...............they say to remove the check valves if you have them inline.
    22,553
    Several people (myself included) have had issues with the stock check valve on the LQ. I replaced mine with a 1/4" npt SMC check valve and it worked great.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Jul 2010
    Central Illinois
    40
    Jason - I have a 2hp pump that came in the package deal, I have been looking at different pumps but that's what I have now. The gauge is reading about 24 psi and the feed is coming from after the filter, the return is right b4 the pump.
    Woody - The LQ is below the water line
    Bama - I have removed the Check valves and still know difference
    The best I can find is everything flows good except b/t the return fitting b4 the pump and the check valve in the return line on the LQ. The water coming from the return fitting and meeting the water coming from the LQ is not strong enough to get in the system
    With a large pump and the correct hose connections, flow that low means that something is defective somewhere. From other reports it is likely that the problem is the Liquidator flow rate valve, but you could also be having problems with a check valve or one of the float valves. The best thing to do is to bypass parts one at a time until the flow rate improves, as you appear to have started doing already.
    22,553
    Here's a quick test. If you have a valve before the LQ outlet in the skimmer line, partially close it off and see if the flow out of the LQ goes up. If you don't have a valve you can either hook up a vacuum to the skimmer or partially block the skimmer outlet to see if that increases the flow out of the LQ.
    Can you take a pic of your setup and post it?
    Jul 2010
    Central Illinois
    40
    When I had the cleaner hooked up to the skimmer yesterday I noticed the flow was working properly. When I removed it went back to doing the same thing reading bt 0 and 1 with the valve open all the way. I'll post a pic also
    Jul 2010
    Central Illinois
    40
    The black tape is test spots
    22,553
    That tells me that you have a very low suction head. That's a good thing as far as the pool goes but a bad thing for the LQ flow wise.
    I assume that the thing I see right behind the LQ is the pool.
    Have you tried moving the outlet to the drain plug of the pump basket?
    That valve right at the pump basket is part of your problem.
    Jul 2010
    Central Illinois
    40
    I put a nipple in the drain plug of the pump basket and no better. Why is the shut off an issue??
    22,553
    You're taking a pressure drop across that valve so the pressure is slightly lower on one side of the valve than on the other. If the valve was farther out in the line you could put the LQ tap between the valve and pump suction and take advantage of the pressure drop across the valve to help the LQ flow. You could also partially close the valve to increase the suction pressure so the LQ would flow better.
    As a second thought, are you sure the impeller of the pump is clear?
    Jul 2010
    Central Illinois
    40
    I put the outlet feed in b/t the valve and pump basket and it has been feeding finally, however the flow is not very strong. It's reading around 2 on the flow meter with the valve fully open. Any suggestions on how to get a stronger flow down that outlet?
    22,553
    Close that valve a little bit. You could also try a skimmer sock in the skimmer basket. That will increase the suction head a little bit.
    Jul 2010
    Central Illinois
    40
    You're the man Bama, that did it. TY for all the help!!!! I'm going to try the sock also, it might help with all my pine needles that keep falling in early season.
    22,553
    You're very welcome.
    We don't often run into the situation where there's not enough suction head to get the LQ to flow because most most pools have enough suction restriction to create enough head to suck the chlorine out if the line. Once in a while we see a pool with a very short run to the pump and there's something (like you're valve) that takes all the suction head right at the pump suction.
    P.S. As an afterthought, you could have placed the outlet of the LQ in the basket drain and closed the valve a little and that would have possibly worked.
    Robins Airman's Avatar
    Jun 2010
    Bonaire, GA
    139
    Please excuse the highjack...where did you all get a fitting for the backet drain?
    Was it a 1/2" fitting with barb?
    Thanks...Bo
    Thanks all for your amazingly helpful advice! Bo
    18x33 Morada pool, 14,100 Gal - 2HP, 2SPD W/Skimmer and Caplet Basket, 125 GPM Waterway ProClean Cartridge Filter System – 8 Gal LQ - TF-100.
    Thanks in advance for all your help!
    God Bless America!
    Apr 2010
    East KY
    51
    Good Question. I could also use this info. I got my LQ today and will be installing this weekend.
    11400 Gallon AG 22ft
    Hayward Sand Filter
    1 HP Hayward XL Pump
    Liquidator 3/8" upgrade, Hayward Needle Valve
    Useful Links: Turning Your Green Swamp Back into a Sparkling Oasis, Pool School, The Pool Calculator
    22,553
    It's a 1/4"NPT fitting with a barb. Home Depot & Lowes have them. You can get a speed fit fitting too which has a larger opening.
