Results 1 to 9 of 9
Thread: removing square drain plugs from skimmer
    This might be a stupid question.
    When removing the square drain plugs from the skimmer should I be turning counter-clockwise or clockwise? The pool company closed the pool and I'm having a **** of a time trying to unscrew the drain plugs. I've been using a wrench to turn counter-clockwise but the drain plug isn't budging. There's not a lot of room in the skimmer for me to get sufficient torque to unscrew the plug.
    Thanks.
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: removing square drain plugs from skimmer
    hmm...any chance you can snap a pic of the plug?
    22,548
    since I've never seen a left handed threaded pipe I'm going with 'righty tighty, lefty loosey'. So counter-clockwise is the way to turn it when looking down on the top of it.
    Mar 2011
    Scottsdale, AZ
    406
    Generally put in with a large T-handle tool.
    Hard to take out with out that I would think.
    Lefty loosey, righty tighty
    If you're using an adjustable wrench, put a short screwdriver through the hole in the end of the wrench to use as a lever.
    If there are two plugs, make sure you know which one to remove and which one to leave alone.
    Support the site
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    You may need a long pair of straight vise-grip pliers to get a good hold on the plug.
    Love TFP? Become a
    TFP Supporter!
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Re: removing square head drain plugs from skimmer
    I really should have another cup of coffee. But square drain plugs don't turn. You mean a square headed drain plug? Then Righty-Tighty, Leftly-Loosy applies.
    darrenw, i know exactly what you are asking, i do this every year myself. Turn those square plugs counter clockwise with a good set of pliers and then you can finish off removing them by hand.
    ~13,500 gallons; Outback AG 24' X 48" (don’t have any idea how old as it was given to us); Hayward Pro-Series S220T sand filter 52 GPM flow rate; Hayward Power-Flo Matrix 1.5 HP single speed pump; Taylor K-2006 test kit
    Jun 2007
    New Jersey
    653
    The 2" square head plugs in my skimmer come right out with a 12pt. 1 1/2" socket and two long extensions. But if you don't work on tractors regularly this might not be in your toolbox.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
