Results 1 to 19 of 19
Thread: Did you know that Vinyl liners contain calcium?
    Jun 2010
    Pensacola FL
    40
    and low calcium causes them to become brittle! Or at least I was just told when I went to pick up some 12% bleach at the pool store. He was told by his "chemist friend" and even drew out the basic formula for vinyl CH=CH2 to show me all the calcium (CH). I tried to explain what a hydrocarbon was but got quite a perplexed look. We ended up agreeing to disagree and I left with no calcium. I told him to look on the bright side, if he's right they will get to replace my liner that much sooner.
    14.5 K inground vinyl
    1hp pump
    sand filter
    Taylor K-2006
    Aquarite SWG
    P'cola FL
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: Did you know that Vinyl liners contain calcium?
    They've never quit trying to sell me calcium for my vinyl liner pool.....................just because their testing equipment says "to add some". You get some really strange looks when you ask them.........."Why?"
    And my adding plain old bleach will cause my liner "not to last the normal 15 years or so." Told them my wife would want to "redecorate" before then anyhow!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    We should come up with some cool T-shirts
    "WARNING - Trouble Free Pool School Graduate"
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by kirbdoc
    That is so wrong on so many levels, it's laughable. As you pointed out, "CH" is a carbon and a hydrogen and has nothing to do with calcium hardness. Vinyl itself is a polymer formed from vinyl groups which is what he was showing (which is actually -CH=CH2 since it's a chemical group, not a standalone chemical) and the polymer known as vinyl doesn't actually have any vinyl groups itself -- the double bonds are all gone since they are what open up to form the polymer.
    Polyvinyl chloride (PVC) is a polymer of groups that look like [-CHCl-CH2-]n which consists of carbon, hydrogen, and chlorine. There are other chemicals added for vinyl liners such as heat stabilizers, UV stabilizers and plasticizers (which is what makes vinyl soft). The plasticizers are complex chemicals (usually phthalates such as dioctyl phthalate, DOP, see here) composed of carbon, hydrogen and oxygen. The UV stabilizers are typically a benzophenone which is composed of carbon, hydrogen and oxygen. The heat stabilizers are typically a barium/zinc-alkyl phosphite which consists of barium or zinc, carbon, hydrogen, oxygen and phosphorous.
    No calcium to be found!
    Apr 2009
    Burlington, ON, Canada
    344
    chem geek. I understood everything right up until 'laughable'.
    But I'll take your word for it....lol
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    I think that you are missing the little-known secret of the actual process, and the conspiracy that endeavors to keep it from you...
    The feedstock that is used in the production of vinyl liners comes directly from the middle range of fractions distilled during the calcium refinement process once the calcium is taken from the calcium well by the calcium drilling/pumping platform. Once these lighter calcium fracs are distilled off, they can be used for many many things, depending upon the amounts and mixtures of other calcium that is added to make them more or less calcium. Once calcium stabilizers and calcifiers are added, the vinyl liner pretty much just 'pops' out of the mixing rollers, needing only a light dusting of calcium to make it ready for the market, otherwise the aggressive nature of the calcium would leech additional calcium from the atmosphere, ultimately leading to a situation that theoretical scientists have called "calcium-deficient atmosphere", a condition under which the vast majority of the earth's calcium is assimilated by the air in an attempt to satisfy the reduction by the vinyl being produced. It is the ultimate virtual doomsday potential of this production process that makes everyone try to convince you that it is all done with hydrocarbons.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Quote Originally Posted by Ohm_Boy
    I hope like crazy that was a joke! If not, you've just matched Richard in the ability to confound me, using words I know.
    Luv& Luk
    -Ted
    Puffin's Avatar
    Jul 2010
    Metro Atlanta, Georgia
    217
    Wow, this got complex fast. I'm reminded of a quote:
    "My cat's breath smells like cat food." -Ralph Wiggum
    19,600 gal, Vinyl, Grecian L, StaRite Dura-Glas 1 HP pump, 3/4hp booster, Pentair Clean and Clear 420 Cartridge filter
    The Pool Cleaner 4x, PoolSkim
    Montreal Canada
    326
    Calcium carbonate is used as a filler in PVC formulations.
    http://www.specialtyminerals.com/filead ... %20bro.pdf
    http://books.google.com/books?id=8j3elW ... CBsQ6AEwAA
    I remember reading an AFNOR bulletin stating the content was 4% or thereabout in pool liners.
    what-is-the-effect-of-low-ph-levels-t24369.html :
    "Putting aside the chemistry and water balance aspects, the low pH could possibly damage a liner by causing wrinkles, hardening and elongation. This is partly due to the acid dissolving the calcium carbonate used as a filler in PVC formulations. Elongation then allows the disinfectant to further penetrate the membrane possibly leading to discoloration."
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by rcy
    Mar 2007
    San Rafael, CA USA
    12,082
    waste, Ohm_Boy is being facetious.
    CaOCl2, those references refer to calcium carbonate filler in rigid PVC. Since vinyl liners have plasticizers to make them softer, I doubt that calcium carbonate is added to them since that would tend to make them stiffer/harder. [EDIT] I am wrong about this -- see later posts below. [END-EDIT] This AFNOR standard may be what you are referring to indicating a small amount of calcium carbonate filler in vinyl liners, but I'd appreciate it if you could verify that (if you have that bulletin).
    I don't know if 4% calcium carbonate in vinyl (PVC) would need water to be saturated with calcium carbonate because the forces that hold it in the liner are probably not like plaster where it is physically integrated in much larger quantities.
    We do know that low pH is harmful for vinyl liners (especially from Trichlor pucks touching liners which are both low in pH and high in chlorine), but we haven't had any reports of any issues from low CH levels.
    Flexible PVC is formulated with relatively large amounts of plasticizer (which functions to increase the flexibility of the PVC resin) and then filled with calcium carbonate. Typical applications are upholstery, wire and cable, gasketing, vinyl floor sheeting, and swimming pool liners.
    Flexible PVC usually contains ground calcium carbonate (GCC), also called ground limestone, as the calcium carbonate filler. Loading levels differ by application, ranging from a low of 10 phr for upholstery to over 500 phr for some flooring applications. A finer precipitated calcium carbonate (PCC) may be preferred for some end-uses.
    http://www.specialtyminerals.com/specia ... xible-pvc/
    Calcium levels should be kept at a minimum level of 200 ppm to avoid corrosive conditions. Higher calcium levels many cause problems such as cloudy water or scaling on the liner surface.
    http://www.vynall.com/inseason_care.cfm
    Liner Care and Maintenance Tips
    Calcium Hardness..........150 to 250 ppm.
    http://www.garrettliners.com/pages/liner-care-tips.php
    Question: What is the ideal water chemistry for my vinyl liner pool?
    Calcium Hardness between 200 ppm and 400
    http://www.kafko.com/main.php?mod=faqsC
    Maintain proper water balance: pH in the range of
    7.2 to 7.6; total alkalinity at 80 to 100 ppm; and calcium hardness at 200 to 300 ppm
    http://www.cgtpoolliners.com/cgt-techni ... ercare.pdf
    Compounded PVC is an inert material in its normal usage. All the components listed below are encapsulated in the PVC matrix. Typical compositions are listed below:
    Component Wt.%
    Polyvinyl Chloride Polymer 45 – 80%
    Inert Fillers 0 – 40 % CACO3, talc, carbon black, TiO2, clay
    Heat Stabilizer 3 – 10% Organometallic compounds of barium and/or calcium-zinc
    Plasticizer 0 – 60 % High molecular weight esters
    Colorant 0 – 5% Organic and inorganic colorants
    http://www.ggc.com/home/friendlyDownloa ... at%204.pdf
    http://www.ggc.com/businesses/msds.cfm
    Support the site
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by dmanb2b
    [center:34irre8g]Close enough
    [/center:34irre8g]
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    OMG! I am SO sorry.
    Yes, I was being facetious.
    I really have never seen a calcium well, a calcium well drilling platform, nor a calcium refinery distillation stack. There is NO calcium refinery in Texas City.
    Mar 2007
    San Rafael, CA USA
    12,082
    James,
    The manufacturers quoting the same standard water balance parameters isn't so relevant since some of these same guys also claimed that bleach shouldn't be used (though some to say chlorinating liquid is OK) so their credibility is a bit suspect. However, as far as an additive/filler, it's clear from your references that granulated calcium carbonate is often used. So the question is whether water that is not saturated with calcium carbonate attacks it or whether it is sufficiently embedded into the vinyl for there not to be a problem as compared to plaster pools that clearly have large areas of calcium carbonate directly exposed to the water.
    I wonder if there some sort of experiment that could be done, perhaps at hot water temperature to accelerate the process, with vinyl samples exposed to buffered water with virtually no CH vs. water saturated with calcium carbonate, both at a pH of around 7.5. We might then see if there is any difference in elasticity, coloration, folds, or other effects. We could also see if the CH and pH rise in the no-CH water vs. the saturated water which would imply leeching and dissolving of calcium carbonate from the vinyl. We've never had any reports of people seeing unusual pH or CH rises in vinyl pools, but then again most aren't checking their CH levels.
    There is also a secondary question, if the calcium is removed what happens? Does it actually damage the vinyl in any way? The primary risk for vinyl liners seems to be either loss or destruction of the plasticizers, which I imagine has little to do with the calcium filler.
    We have what is probably tens of thousands of pool years of very low CSI in vinyl liner pools with essentially no complaints at all. So I can't imagine that anything is actually going on here. Our data collection is haphazard, so we can't rule out small effects, but if there was a large effect we would have heard about it by now.
    22,551
    I'll be the guinea pig. We have almost no calcium in our water and our fill water has zero (less than 20ppm). The pool will get real close to zero during the season because we average 60" of rain a year here and are not adding any back to it. However it may take 10 years or so for the results!
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Mar 2007
    4,160
    (probably should be split to The Deep End)
    Jason, while I don't know the chemistry like the others - I like your line of thinking on this. If it happened (the cal being leached from the liner), wouldn't chlorine be leached from PVC, if the cl levels got low?
    Dave (Bama), you're a brave man I didn't keep 'scientific' track of the liner pools I didn't add any calcium to, nor check the CH levels, but acidic water was always present in heat exchanger failures and brittle 'new' liners.
    Luv& Luk
    -Ted
    Mar 2007
    San Rafael, CA USA
    12,082
    Thanks for moving this to The Deep End where this discussion really belongs.
    I ran into some sources that shed some additional light on this calcium carbonate in vinyl issue. This link says the following:
    The most widely used fillers in flexible and semi-rigid PVC are grades of dry-ground, wet- ground, or precipitated calcium carbonate derived from limestone or marble, which are predominantly calcite.
    The disadvantage of using high levels of fillers in flexible PVC is the reduction of tensile and tear strength, elongation at failure, toughness at low temperatures, abrasion resistance, and resistance to attack by moisture and chemicals.
    This is consistent with what I wrote earlier that I thought that higher levels of calcium carbonate would be counter to the goal of having more flexible vinyl so that implies that the level of calcium carbonate is probably kept lower in vinyl pool liners.
    Then there is this link which has the following very interesting information:
    Then we have fillers. Calcium carbonate is often used as a filler in plastics. Depending on the amount used in a blend, calcium carbonate can increase the modulus, increase the hardness and at very high loadings decrease the cost of the formulation. It was found that at levels less than 7% by weight the physical properties were not significantly affected and that, at levels over 20%, the physical properties were compromised and the chemical resistance severely compromised.
    Stanford et al. (1979) showed that high filler loadings resulted in excessive weight gain and, thus, poor chemical resistance. A PVC formulation incorporating high calcium carbonate amount is by far the most significant negative factor in acidic leachate environments. When exposed to acidic leachates, and with 37% HCl, formulations with less than 7% calcium carbonate, incorporating a branched or linear phthalate, had less than 5% weight change and €“ more importantly €“ were still very flexible.
    Calcium carbonate filler loadings of greater than 7% should be avoided in low pH (acidic) environments.
    So as long as the amount of calcium carbonate in vinyl is low (< 7%), it seems that even acidic conditions don't cause serious problems. The implication here is that low CH levels may not be an issue with these low levels of calcium carbonate.
    We may never know for sure about this issue, but at least we've got more info to ponder.
