Results 1 to 13 of 13
Thread: First season using BBB
    Jul 2010
    Central Illinois
    40
    I opened the pool and everything looks good from the fall closing. I decided to ditch the N2 and use the BBB method and have a Liquidator in the system. The pool in 18 x 4.5, comes out to 8566 gal. Just wanting to make sure on my numbers
    ph 6.8
    FC 1.5
    cc 0.0
    TA 70
    Cya 60
    I treated the ph first adding 37 oz of borax according to pool calculator
    18' x 54" Round AGP, Hayward pump/Cartridge Filter, 8 Gallon Liquidator, and TF-Test
    Jan 2010
    Central Valley, CA
    233
    Re: First season using BBB
    your minimum FC is 5 for CYA of 60. Refer here: pool-school/chlorine_cya_chart_shock
    Dose to 7 or 8 and see if you can hold 5 or better as a minimum for 24 hours.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
    Remember to double check to the PH today. The common PH test reads levels lower than 6.8 as 6.8, so your actual PH might have been lower.
    Jul 2010
    Central Illinois
    40
    Ty both I will make the adjustments and check back in
    30,421
    w_a,
    tell us how the water looks when you check back.
    Jul 2010
    Central Illinois
    40
    wanted to check in
    FC 4.5
    CC 0
    TA 100
    CH 220
    CYA 60
    PH 7.5
    22,550
    Re: wanted to check in
    That looks good.
    Jul 2010
    Central Illinois
    40
    Thanks Bama!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    No to contradict but your FC is a little on the low side...
    Jul 2010
    Central Illinois
    40
    FC 4.5
    CC 0
    TA 100
    CH 220
    CYA 60
    PH 7.5
    Water is crystal clear
    11,969
    If you refer to the CYA Chlorine chart, you will see your minimum FC level for a CYA of 60 is 5. You NEVER want to go below your "min" to avoid the potential for an algae bloom. You may need to adjust the setting on the liquidator if you are not staying above the "min" level.
    22,550
    Thanks FPM, don't know why I missed that.
    She's right of course. You should always keep your FC above the min for your CYA.
    Jul 2010
    Central Illinois
    40
    Will do!! I have my pump running 24/7 now, when Can I knock it back to 12 hrs??
