Results 1 to 9 of 9
Thread: aqua-rite generator installation
    Jan 2010
    Claremont california
    100
    Hello friends,
    I want to install an aqua-rite chlorine generator. I am looking at my pool’s equipment plumbing, and I noticed that heater’s copper pipe water return had a very short expand. It appears that I do not have a pipe long enough to install my generator. I am looking for alternatives so that I can overcome the following problems.
    Problems:
    1. Short water return pipe.
    2. Pool main copper pipes coming from pool very close to heater.
    3. Close proximity of heather to filter and pump.
    Options: I can cut all of the pipes to make the proper installation of the generator. But I still have the problem of the heater being very close to the copper pipes.
    I just added a photo to show the installation. Copper pipe.
    Thanks in advance, I welcome any input,
    George
    Copper pipe is
    22k plaster pool kidney shape. Pentair 4000 de series 48 ft. 2 SKIMMERS, 2 drains (pool and spa), 3 returns (2 pool and 1 spa) gas heater and pentair intelliflow , Underwater pentair light.
    Re: aqua-rite generator installation
    If you post a photo it would help us be more specific.
    When working in a tight space the usual solution is to cut one of the pipes and run out to the side and back, mounting the SWG on one of the horizontal runs.
    Jan 2010
    100
    Excellent Idea!
    Ft Lauderdale, Florida
    1,455
    An obviously modified heater stubout. Not too concerned with the left side stubout, as this is the cold water inlet side. The right side is the outlet side, and will be about 10-15 degrees higher than the inlet water temperature.
    However, when the pump shuts down, there should be a firemans switch protection device to allow the pipes to cool down first. The normal length of stub out, either 36" or 48", allows more protection from excessive heat. Going straight to PVC, sch 40 pipe, is not common for a heater connection, unless there is a firemans switch. This is commonly a CPVC (heat treated) adapter fitting.
    I would recommend getting a new outlet heater stubout, and replumbing it correctly to fit your cell.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    1,455
    Just realized another thing, the outlet stubout should be positioned down, and not horizontal. This allows the highest point after the heater,which is pvc, to entrap the hotter water from the heater, leading to a potential pvc meltdown.
    I'm surprised you have not encountered this situation yet. That short, modified heater stubout is not a safe condition.
    Jan 2010
    100
    Jan 2010
    100
    I went to my local pool supply and was not able to find the proper cpvc fittings. Is there any other part I can use to complete my project?
    Please advice,
    George
    1,455
    Jan 2010
    100
    Quote Originally Posted by Poolsean
    No I do not have a local grainer. But, I can always order in line?
    Thanks for the info.
    George
