Thread: Jandy Cartridge Filter, CS Series 100 150 SOLVED
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    From the manual it looks like the CS100 (filter C-8410) and CS150 (filter C-8414) have the same size housing and same size filter measurements (Diameter: 8-15/16" Length: 23-5/16" and 4 inch ends). The difference is the amount of filter media. 100 sq ft vs 150 sq ft.
    My question why couldn't you put in the larger filter and be good to go?
    I think this is what's on my pool. Still waiting but from the distant pictures it looks to be it. It's on a 17K gal pool with 1hp pump.
    Thanks.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Jandy Cartridge Filter, CS Series 100 150
    The manifold to which the cartridge attaches is probably going to be different.
    Its not uncommon for manufacturers to just cram more media into a cartridge.
    We do it (our CNC 150 and 200 cartridges are the same size and go into the same housing).
    Just be aware that you don't always get longer cleaning cycles by doing this. There is a point where you reach diminishing returns due to pleat spacing being too tight. This particular model is basically a copy of our Clean and Clear filter though, and appears to be similar in size to ours so I'd bet it would function ok.
    In-ground Filters Engineer
    Pentair Water Pool and Spa, Inc.
    www.pentairpool.com
    1620 Hawkins Ave
    Sanford, NC 27330
