Results 1 to 8 of 8
Thread: True or False? Advice From A Pool Store Guy
    Aug 2010
    Livonia, MI
    18
    One of the pool stores we dealt with in researching our pool gave us a piece of advice that I wanted to float (pun intended) past the experienced owners at TFP. He advised us to replace the gaskets on skimmers and returns every 2-3 years. I'm keeping a notebook handy with things to remember and wondered if I should add this piece of advice as a reminder while we go about learning to become functional pool owners. Opinions?
    - Michelle in SE Michigan (suburban Detroit)
    54" Desert Spring Doughboy 21x41' oval AG pool, with 7' deep end on half the pool - approximately 23,000 gallons. Including 2 returns/skimmers/main drains, 300lb Doughboy sand filter, 2HP Doughboy pump.
    30,432
    Re: True or False? Advice From A Pool Store Guy
    Did he say why?
    22,553
    I don't replace anything unless there's something wrong with it. There's no use replacing a static seal on anything unless it's leaking.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    IMO, you are doing more damage to the liner by replacing them, if they haven't failed.
    Luv& Luk
    -Ted
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    I like to keep it simple.. If it isn't broken don't fix it. If it's broken, fix it the right way and be done with it.
    Jul 2008
    McDonough, GA
    98
    I just heard the same thing at the pool store last weekend. They said it was because I am using bleach for the pool and it would cause the o-rings and gaskets to deteriorate quicker.
    Vinyl 18x36 inground pool, cart 4030 filter, tristar VS pool pump, T-15 SWCG, raised pre-plumbed fiberglass spillover spa w/12 jets, tristar VS spa pump, Aqualogic pl-plus-16v
    McDonough (Ola), Georgia
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sounds like a great way for them to make money selling overpriced pool equipment parts.
    Ike
    30,432
    Well, that makes sense, doesn't it?
    I'm sure they would like for you to switch to 3" tablets because they don't....uhhhh, well never mind, they have the same thing in them as the bleach so that won't work.
    So, let's go ahead and switch to powdered.....X!!$%&?!! Doggonit! same thing as bleach, again!!
    Oh, I got it now, they want you to switch to a Salt water generator so your gaskets will be safe and sound and won't have to get eaten up by that nasty Chlor...... Holy Benoli! No matter what they want you to use, they all contain EXACTLY what's in bleach...CHLORINE!! Well, I'll be!!
    BBB teaches you to understand pool water chemisty, and through careful testing and knowing what to do with the results, allows you to rid yourself of pool stores that, while perhaps well intentioned, simply waste your money.
