Thread: Hayward pump running sheer descent - no flow
    But it is running.
    Is there a link on this fine site to troubleshoot a pump that runs but isn't moving water? It was running a month ago as I recall (only have it on 5 minutes per day to keep circuit fresh).
    Thanks As Always!
    Bob
    23,000 gal in-ground, Aquarite salt sys, Intellitouch i7 +3, Hayward cartridge filter (4) C-5025, Polaris 280 Pool Cleaner, 3/4 HP booster pump, Hydrazzo plaster.
    22,542
    Re: Hayward pump running sheer descent - no flow
    Is the pump basket full of water?
    does the pump sound normal?
    Is the shaft easy to turn?
    does it shoot water out if you open the filter air valve?
    That'll get us started.
    Thanks Dave.
    I took cover off pump basket - It was half full of water. I filled it and turned on pump and water was sucked into pump and sheer descent followed momentarily.
    When cover replaced with basket full, same thing, then stops.
    No water from spigot on top of pump.
    Took one way valve apart upstream from pump. Blue flapper has spring and moves easily.
    Ignorant as to what supplied water to this pipe (what vavle may not be turing to let water to this pipe?
    Thanks Bob
    [attachment=0:35ndfvm2]IMG_3865.JPG[/attachment:35ndfvm2]
    Thanks As Always!
    Bob
