Thread: Newbie needs heater hookup advice...
    Oct 2010
    Eastern TN
    172
    I'm considering adding a heat siphon digital pump to my system. I understand that it needs to go between filter and salt cell. Do I leave it inline always and rely on thermostat or do I need to take it out of the circuit at low flows? Is it normally plumbed with a Jandy valve or straight PVC?
    How does the easy touch integrate with the heater's thermostat? Does it control the heater?
    Plaster pool inground 22,000 gallons with spa. Pentair Intelliflo, IC40 salt generator, WiFi control/Easy Touch.
    Hayward 1.5 HP pump on 750 gallon spa. Sand filters. Auto chlorinator on spa. Auto water level. Dolphin M500. TF100 XL with Speed Stir. Apera Instruments AI311 PH60 Premium Waterproof pH Pocket Tester
    Re: Newbie needs heater hookup advice...
    The typical install simply places the heater in-line. Any lock outs for low flow rates will be handled by the Easy Touch. You can plumb in a heater bypass, but most people don't as it doesn't usually make a huge difference and increases the complexity.
    The Easy Touch is normally setup to control when the heater comes on and the heaters thermostat is disabled.
