Thread: shock amounts with calcium hypochlorite
    Why does the pool calculator suggest using so much more shock than on the back of the product. I have Leslie's SuperPowderPro 73% and it says to use 1 lb/13,500 gallons. It is way more than that if I use the suggested level for green algae on the Pool Calculator. Thanks!
    24,000 gallon chlorine plaster in ground
    Triton II Sand Filter
    Pentair Pool Sweep/Cleaner
    Re: shock amounts with calcium hypochlorite
    That is a reasonable amount to use if your CYA level is zero.
