Results 1 to 7 of 7
Thread: Grass getting into filter/Replacing filter cartridges
    Jul 2009
    Houston
    74
    We have an approx 17,000 gallon in ground pool. Inevitably, despite best efforts, grass from the mower finds it's way into the pool. I try to remove it with the pole/net attachment, but the grass is often so fine that it passes through the net. The two skimmers obviously won't keep small blades of (a lot) of grass from making its way to the filter, which contains four, 4 ft cartridges.
    Two questions:
    Aside from removing the cartridges every month and cleaning them, is there any other way to clean the grass out of it?
    Second, how often should the cartridges be replaced? We're now entering or third year using the same filter cartridges.
    By the way, this is not a salt water pool.
    Thanks for any advice!
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Grass getting into filter/Replacing filter cartridges
    Skimmer socks will stop all that. I use queen size knee high hose in mine. Alot cheaper than the official "skimmer socks" at the pool store.
    I use the queen size cause it's easier to put around my skimmer basket, not because I wear them
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Quote Originally Posted by trclac
    I guess when they start to come apart. Most people seem to have trouble with the little bands that hold the pleats together. Some have even hot glued them back together when they break.
    Lynn
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,602
    Possibly consider bagging the lawn clippings around the pool area if you have one?
    Prav's Avatar
    Nov 2010
    Miami, FL
    94
    +1 on the skimmer sock. My Pinch-a-Penny sells 4/$5, and they are more durable than Granma's knee-his!
    14'x30' (est. 14K gal) w/spillover spa (est. 500 gal) - 1995 // Diamond Brite Blue Quartz - 2006
    Hayward SwimPure Plus T-15 - 2013 // Zodiac MX-8 - 2013
    Plain ol' Intermatic mechanical timer // Pump: 1 HP Pentair SuperFlo - 2012
    Filter: Hayward C17502(S) Cartridge Filter - 2011 // Heat Pump: Sunrunner/Aquapro 1300 (127K BTU) - 2011
    Jul 2009
    Houston
    74
    Thanks all. As for bagging, I do that, but clippings still make their way in, especially if I use the weed-eater near the pool. But my wife is on her way to get the stockings now.
    It is time to replace a filter cartridge when either it gets a hole in the filter fabric, the core collapses, or the filter pressure after cleaning overnight in dishwasher detergent goes up by 6 psi over what it was when the filter was new.
