Results 1 to 7 of 7
Thread: New Tf-100 first test results
    Nov 2010
    Calera, Al
    271
    Ok, So my pb has still not turned over the pool to me, but I could not stand it anymore. I have had my new toy the tf-100xl w/speed stir for about two weeks and it is killing me to not use it. Last evening I decided I was taking the situation into my own hands, and took a h2o sample and commenced the inaugural test. The results are as follows:
    Fc:0
    Ph:7.8
    TA:160
    CH:330
    CYA:50
    The water is crystal clear at six feet you can makeout the phillips head screws on the floor returns and drains and which way the pattern is on them. It is a new pool and in sun all day. According to the pool calculator I need to add 133 oz of bleach to come up to 4ppm on Cl and 44oz of MA to bring ph Down to 7.3. Is this correct? Am I missing anything else?
    17,000 gal, IG Gunite Diamond Brite plaster Kidneybean,w/7x11 tanning ledge& 3x5 swimout bench,244T 300lb Hayward Pro high rate sand filter(63 GPM) , Hayward 1Hp Super Pump w/3/4 hp booster pump, Polaris 280, Laars Lite 2 175k N/G Heater, Tf-100, Speed stir
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Re: New Tf-100 first test results
    I don't see anything wrong with that suggestion. With FC at zero, it won't stay clear long. Good for you to take things into your own hands.
    Mar 2010
    Spring, TX
    1,082
    I dont see a test result for CC?
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by mynewpool
    Even if there were a result for CC, this is a new pool and you should not shock a new pool, so it really doesn't mean much in this particular situation.
    Rob, please be sure to speak with your PB so that you don't do anything that might void his warranty. I support you taking the inititive just make sure you are covered in that regard.
    Nov 2010
    Calera, Al
    271
    Ok so I added 133 oz bleach yesterday, got to retest today. Results are as follows:
    Ph:7.8
    Fc:3
    Cc:.5
    Tc:3.5
    Ta:160
    Ch:500
    Cya:50
    So per the pool calculator next I added 33 oz bleach and 44 oz MA, slowly in front of the return with the pump running. I waited about 1 HR and tested the ph and Cl again, which were:
    Ph: 7.2
    Fc:4.5
    Cc:0
    Tc:4.5
    Anything I need to address, or does everything else look ok? for a new plaster 3 wks after the fill...
    FPM, the pb was to hand it over to me last sat, but did not make it. but heleft me an instruction manual. So, I do not think there wil be an issue. At least I hope not, but thanks to this site I have been able to pretty much figure most of it out so far! so thank everyone!!
    Your TA and CH levels are both a little high. There is no immediate problem, but you want to try and keep PH at 7.6 or lower until you have time to bring TA down a little.
    With CYA at 50, I would raise FC a little higher than that to make sure it doesn't go below 4 by the end of the day.
    Nov 2010
    Calera, Al
    271
    Ok, thanks, looks like I will be adding 50 oz of bleach this evening.
