Thread: Grilled potatoes
    Apr 2011
    Marietta, GA
    9
    Grilled potatoes
    This is an easy one, and is a big hit with everyone I've fed it to.
    Get new potatoes or red potatoes, and cut them into bite sized peices.
    Put the potatoes on heavy aluminum foil, large enough to make as flat a pouch as you can. If you are making lots of potatoes, make serveral pouches. They cook better when the potatoes are flatter in the pouch.
    Coat the peices with olive oil.
    Mix in slices of butter.
    (optional, you can also add sliced onions and/or garlic)
    Shake GrillMates Montreal Steak Seasoning very generously over the potatoes.
    Seal the pouch(es).
    Cook on medium heat (400) for 20-40 minutes.
    Key here is to check it after 20 minutes and make sure your potatoes are crisping, but not burning. If you poen to check them, stir them and leave the pouch open. Also be careful not to puncture the bottom of the pouches, as the olive oil will ignite and charr your spuds.
    Enjoy.
    --Rick
    Guessing 27,000g
    18'x40'x8' IG Vynil lined pool
    Sand filtered
    1-1/2 hp pump
    swcg system
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Grilled potatoes
    Welcome to TFP!!
    Thank you for that delicious sounding recipe
    Luv& Luk
    -Ted
    Apr 2011
    Somewhere on the Emerald Coast
    156
    I do something similar ...
    Cut spuds in one inch cubes into the heavy duty foil (spray PAM first) - then do the same with onions - (I like the onion pieces quartered but the wife doesn't - adjust as needed). Add your salt, pepper, garlic powder (not garlic salt) then add butter on top so the spices filter down as the butter melts.
    What the heck is GrillMates Montreal Steak Seasoning? (well - steak seasoning! DUH!) OK - I looked it up - sounds great!
    I'm gettin' hungry now ... it's all your fault!!
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
