Thread: Pool light voltage reading 88 volts
    iam in almost the same shape i took out bulb took my volts meter to check voltage reading 88 volts what should do or try next
    Split off of this topic. JasonLion
    16\32 30,000 gallon inground pool triton II sand filter 3 h.p pump hayward chrlorinator
    22,550
    Re: Pool light voltage reading 88 volts
    Low voltage readings are almost always loose connections. Turn off the power and go thru the system and check all the connections. Make sure they're clean, tight, and secure. It could be either conductor.
    Jan 2011
    153
    What you need to do is check you power at the junction box for the lights.. Then remove the bulb and check your power at the light.. If you have 120v at the junction box but lower voltage at the light then your lights bad.. If you have lower voltage at your junction box you will need to find where it's starts to drop voltage and fix it there...
    Thanks
