Thread: Compupool wiring question
    Jun 2010
    Pearl, MS
    49
    My SWG showed up today! It came set to 220V - I need 110. I haven't opened the unit yet, but changing the jumpers seems simple enough. Here's my question - the power cable is just bare wires; green, red and black. For 220V, my guess is the red and black are the hot leads. What about 110V?
    Larry
    16x28 vinyl inground kidney, 1HP pump, sand filter, Compupool SWG, 11K gallons
    Jul 2007
    Brisbane, Australia
    874
    Re: Compupool wiring question
    for 220 red is active, black/blue - neutral, green/yellow - earth
    i'd say it would be the same for 110, the jumpers just switch the coils used in the transformer.
    22,553
    In the US we use a little different terminology. Red would be L1 (or Hot), Black would be L2 (or Neutral) and Green is ground. On 220 volt split phase systems like we have here in the US there would be no neutral in this situation.
    Jun 2010
    Pearl, MS
    49
    Thanks for the help! Another question; the manual shows connecting the SWG to the pump timer. Seems like you would need to have power to the SWG all the time for it to retain its program memory. Do I need to have a constant power source and just set the SWG timer to come on during the pump run cycle?
    Larry
    22,553
    If I read the manual correctly the swcg has a pump timer built in and you can power the swcg all the time and use it's timer to run the pump.
    It will remember all of it's settings even if it loses power, so you can wire it to an external timer if you want to.
