Results 1 to 14 of 14
Thread: Where to buy bleach in austin
    Aug 2010
    Austin, TX
    200
    I've been getting Clorox from costco for $9, 3x190oz containers. Does anyone know of a better source?
    (probably does not belong in this particular forum)
    38K Gallons IG, Intelliflow VS-SVRS, 30GPM 24/7, 72sqft DE Filter, Spectralight UV, Jandy C1900 driving Liquid Chlorine and Acid (toys, I know..), Jandy LXi gas heater, Aquacal SQ175 Heatpump, Riverflow Competition swimmer, Jandy automation, Touch and iAqualink, Pebblesheen | The Build
    Feb 2011
    Central Texas
    187
    Re: Where to buy bleach in austin
    Nope. Been buying at HD for ~ 4$ per. Probably should hit Sams and see what they have. I wonder if there is a chem supply that has it in carboys for cheaper.
    IG 23K Gal, Quad DE 80, PebbleSheen, Intelliflo VS+SVRS, MT 400 NG, Stenner Pump
    Jun 2010
    Austin, TX
    32
    I just bought 2 from HEB for 2.79 each. Dunno if that was a special or not.
    3900 Gallon (18 x 8.5 x 5) Partially In Ground Fiberglass Pool -- 2" Schedule 40 PVC -- Hayward P4 Controller -- Goldline Aqua Rite Turbo Cell Salt Chlorinator -- Hayward 2 Speed Max Flo II 1 HP Pump -- Hayward SwimClear 225 sqft Cartridge Filter -- Hayward 250K BTU Natural Gas Heater -- Endless Pool Fastlane Swim Machine -- Cover Pools Manual Track & Reel Security Cover -- TF-100 Testkit
    Feb 2011
    Central Texas
    187
    If those are 1.5 gallons, that is a good price.
    Aug 2010
    Austin, TX
    200
    Quote Originally Posted by shakenbake
    Price dropped to $7.24 for 3x182oz containers of 6% clorox at costco.
    Aug 2007
    Austin, TX
    341
    I use Sams. $7.24 per case.
    20k Gunite/Prism Blue-Pebblesheen, Pentair Tagelus TA-100D Sand Filter, Heliocol Solar Water Heater, 2 bubblers and 2 waterfalls installed 2007, 3hp IntelliFlo VS Pump 011018 installed 2013, Aquabot Turbo T4 RC and Stenner 45MHP10 w/The Liquidator container installed 2012.
    Antigua Spa by Artesian Spas: 325 gl, 52 jets, 6 hp 2 sp & 6 hp 1 sp, Circulation System 24 Hour Whisper Pure, Ozonator, LED digital lighting, The Artesian Pillowfall installed 2007.
    Retired: 2hp Pentair Whisperflow, Legend Platinum w/booster pump, PH Adjuster
    Pretty sure I bought bleach for $2.54 per 182 oz bottle (6%) at HEB in Round Rock last week.
    45K gallon IG old (1950s) concrete pool (white plaster)
    Rectangular 20' by 40' with 12' deep end
    one skimmer in deep, two returns in shallow
    1 HP Hayward pump
    Hayward Pro Series 300 lb sand filter
    Aquabot T4
    TF100 Test Kit
    Just bout 15 gallons at SAMs for the $7.24 per 3.
    In ground Pool and spa Specification
    Free form
    18000 Gallons
    7 person spa¬*
    Tr100 Sand filter
    Pacific Blue Hydrozo plaster
    1 3050VS for pool and spa¬*
    Raypac 400btu
    Polairs 280 with booster pump
    Inteli touch automation¬*
    3 Pentair LED's
    I put in my pool 2 years ago and ran with tabs without any problems -- never tested stabilizer levels and haven't had to deal with excess stablizer. I was recently caught in the wildfires here in Spicewood so I had to drain my pool and during my clean up I started reading on-line more and more ... and now I am considering dropping the autofeeder and installing a pump with bleach.
    It is a bit hard for me to wrap my head around how much bleach I am going to need for my 30,000 gallons. It didn't seem to use too many tablets in the feeder -- I only needed to replace them ever other week or so...
    First, do we have any updates on the best (cheapest) or strongest source of bleach in Austin?
    And second, anyone want to hazard a ballpark range estimate of how much bleach I will need on a regular basis ( I am quite aware that there are all kinds of factors here -- but I don't know if I am talking about .25 gallons or 2 gallons a day... )
    Thanks in advance,
    David
    Austin, Texas
    30,000 gallon Gunite/Pebble
    Pentair Clean and Clear Plus CCP 520 Cartridge 150GPM
    Pentair Whisperflo WF-28 2HP Pump
    Delzone Eclipse 4 Ozone Generator
    Aug 2010
    Austin, TX
    200
    Mine ranges from 1 to 0.25 gallons of 6% Clorox a day. But it's complicated by using an ORP system, PH levels, Borax, etc.
    How many gallons does your feeder tank hold? The chlorine container for the intellichem is only 4 gallons. I don't think I'd be happy to be filling that puppy up every 4 days if it's going to use a gallon a day!
    24' round 15,000 gallon
    30,403
    EQArtimus,
    You can do the math backwards by assuming that a healthy pool uses about 2-3ppm daily in your climate (but that can vary with bather load, sunlight, etc.)
    That'll work out to about a gallon of 6% clorox daily. If that task is daunting, you might consider the convenience of an SWG.
    However, since you have learned about the excess CYA side effect of tabs, and since tabs have been successful in your situation, you could simply test CYA more often (preferably not pool store testing) and understand what to do about it if the CYA gets excessive.
    You could also combine tabs and bleach. The whole idea with BBB is testing and understanding what to do with the test results.
    Oct 2007
    Central Texas
    104
    EQArtimus,
    I live about 5 miles west of Buda and have used the LQ for about three years. I am about to convert; probably trying tabs first. If the cost of partial drain/refill to control CYA is excessive I may switch to SWG. Heck, my salt level is already 2900 from all the bleach I have been using.
    IMHO, LQ is great for some but is really a pain if you have a large pool exposed to the Texas sun. The chlorine load is just too high to make the LQ convenient. The relentless hauling of bleach from the store to the pool, the refilling and the required LQ maintenance, like cleaning white stuff from the floats, has all combined to make the system too burdensome for me. If I was retired, I would probably keep it but I'm not.
    Do yourself a favor, stick with the tabs. Like the old saying goes, the cheapest chemical you will ever put in your pool is water.
    Light grey plaster, stone coping, 38K gallon Roman shaped pool with a shallow end beach, table and bar stools, deep end bench and waterfall (Intelliflo 4X160). Taylor K-2006, Pentair 320 chlorinator, Intelliflow VF, Quad DE 100. 4 ColorLogics, 3 skimmers, 14 wall returns, 13 floor returns, TurboTwister slide, autofill and miles of pvc.
    Jan 2012
    Round rock texas
    18
    I'm trying hybrid appoach, bleach in winter and tabs during summer, found Home Depot starting to carry off brand 1 1/2 gal for 2.99. I shop there all the time so works for me but noticed don't stock much of this. I think trial product for them. I'm still trying to determine draining needs but replacing can solve more than CYA problems. I don't think I would want to never do parital drains.
