Results 1 to 8 of 8
Thread: New to the forum, but Veteran Griller. Advice inside.
    Apr 2011
    Marietta, GA
    9
    A big hello to TFP.
    I dont know too much about pools at the moment. But I am learning.
    I've been grilling almost all my life, and I DO have some advice an a broad range of subjects with regards to grilling.
    If you on an Ipod or Iphone, I'd recommend getting the Weber "On The Grill" application. This app has a slew of recipes for grilling, and will even make you a shopping list for yoru ingredients. For those of you without the apple hardware, get your hands on the Weber Big Book of Grilling. It's got most of the same recipes.
    I'll sound like a Weber ad here, but I also use a Weber grill. You'll pay a lot more for them, but they last much longer than the cheaper brands. Mine is the $500 model and I've got 8 good years out of it and it still rocks. The electronic starter still works.
    And now for a quick recipe. If you like pork, get your hands on a large pork tenderloin. I get the big ones, between 5 and 10 lbs. Get heavy duty tin foil, and rest the meat, fat side down on enough to completely wrap the tenderloin once. Dont wrap twice or it will increase your cook time greatly.
    Get your hands on Dales marinate and / or Allegro's marinate. I like both, and I mix them. Pour half & half over the meat, enough to coat it all and make a small pool in the bottom. Close the wrap, and grill it on medium head (400 degrees) for about an hour.
    If you have a meat thermometer, stop cooking when you hit 165 - 175 degrees at the center.
    Let it sit for about 10 minutes, and carve into thin slices. This can be served platter style or on sandwiches. And the leftovers keep wonderfully in the fridge, so cook a larger portion.
    --Rick
    Guessing 27,000g
    18'x40'x8' IG Vynil lined pool
    Sand filtered
    1-1/2 hp pump
    swcg system
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: New to the forum, but Veteran Griller. Advice inside.
    Thanks Rick... I too like to grill and appreciate your post. I will give it a try..
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Apr 2011
    Somewhere on the Emerald Coast
    156
    Are you using a Weber charcoal or gas?
    I used to grill on charcoal but gas is quicker ... yeah yeah - I've heard all the stuff about slow cookin, but I always had a hard time keeping a consistent level of heat - gas gives me that. I'm impatient too.
    20,125 gal. (2,690.6 c.f.) In-Ground / Concrete (Gunite) / Pentair Tagelus TA-60-60D Sand Filter / Pentair Whisper Flo Pump Model WF-24 @ 1HP / Hayward Veri-Flo Valve Model 710 / Taylor FAS-DPD K-2006 test kit / Pool School student
    Apr 2011
    Marietta, GA
    9
    Gas! I have no patience for charcoal.
    Guessing 27,000g
    Sand filtered
    1-1/2 hp pump
    swcg system
    SW Georgia
    300
    Quote Originally Posted by WiseguyFish
    amen
    35K IG Vinyl 20 x 40 self built pool, Hayward Pro Series High-Rate Sand Filter 31" 98gal/min, Hayward TriStar 1.85hp, Hayward 400btu heater, BBB method w/Hypo, Jazz light w/matching fiber optic rope lighting around coping w/syncronized color wheels. Concrete Paver deck.
    guamguy's Avatar
    Feb 2010
    Guam, USA
    388
    Gas takes all the fun out of BBQ! I used to use gas, but have converted to charcoal. I now have 4 charcoal BBQ's, including a smoker I built from an old 80 gallon air compressor tank. Charcoal grills are more versatile, you can even smoke a small brisket on a Weber kettle grill. Just try that with gas Don't get me wrong, gas grills do have their place, but if you want to cook more than just the basic barbecue stuff like burgers, hotdogs and steaks, invest in a charcoal grill, you won't be sorry
    12,800 gallon IG plaster kidney-shaped pool, waterslide, 800 gallon spa.
    1HP 2 speed Sta-Rite pool pump, 1.5 HP Sta-Rite spa jet pump. 2 skimmers, 1 main drain
    Purex-Triton TR-60 325 lb.sand filter. 2" Plumbing, Intex SWCG, TF-100 test kit.
    Link to pics of my pool! http://www.troublefreepool.com/my-oasis-t26558.html
    May 2011
    lebanon tn
    370
    I like both gas and charcoal. Gas is nice because I'm cooking in <5 minutes, but charcoal as pointed out can be more versatile.
    Am planning an out door BBQ pit, with open fire and stone oven- won't happen for a couple years yet, but planning it eventually!
    Also do alot of open fire cooking while camping...
    24ft x 52in AGP 18000 gal
    sand filter, 200#,1.5 hp single speed pump
    Wood deck (still in progress...)
    Apr 2010
    Central Kentucky
    43
    Thanks for your post Rick and welcome to TFP.
    Keep posting recipes and we will enjoy them.
    Keep reading TFP forums and you will be a pool pro before long
    Intek 15' diameter X 4'deep 4,800 gallon AG beginner pool, updated with a Hayward sand filter, 60GPM pump. TF-50 Test Kit. Upgraded to TK-100
