Results 1 to 9 of 9
Thread: scaling on tile and grout
    here are my #'s
    salt 3000
    fc 3.9
    tc 3.9
    ph 8 (adding acid now)
    hardness 200
    cya 55 (adding 3# so I'll be up for SWG recomm. range)
    ta 80
    these numbers are from the Pool store, as i only have a wmart kit.
    here are 2 photos also.
    What have i neglected to have this happen, this is not new, it was there last summer. Is there any way to remove it?
    hope someone can help me.
    thanks,
    dana
    danamomof8
    2005 - 20K gallon gunite, aquarite turbo cell SWG, 3-5-3.5 depth, pentair 60sq ft DE filter
    30,421
    From it's appearance, I would say it's efflouresence.....leeching of minerals from the grout or tile.
    Start with a dilution of 5:1 muriatic acid (wear rubber gloves) and see if that doesn't remove it. If no luck, increase the strength of the muriatic until you see it start to foam when you apply it to the area to be cleaned. Don't use any stronger than necessary to remove the offensive area.......it'll have a tendency to eat your grout a little if you get it too strong.
    I believe that will remove it. You may have to do it again in a year or so.
    i forgot to mention there has been a lot of days that i left my pool level WAY up there. don't know if this makes a difference in what it is.
    dana
    danamomof8
    30,421
    Even if it's calcium scaling from the pool (your current numbers don't really seem to indicate that) the cure will still be the same....muriatic acid.
    How will i get it on there, toothbrush (or will the acid eat it up)?
    dana
    danamomof8
    wardsntx's Avatar
    Jun 2007
    Spring, Texas
    223
    duraleigh,
    our pool was only started a few weeks ago and I am already seeing the same thing. Is this typical with grout and mortar?
    Also, just to make sure that I have the dilution correct, 5 parts acid to 1 part water. Is that right?
    Jay
    36' x19' Freeform, 16' waterfall w/ groto and slide, 5' x 10' sundeck, 12" raised spa. Pentair IntelliTouch, Pentair IntelliFlo 4 x 160, Master Temp 400, IntelliChlor Chlorine generator, Aqua Blue PebbleSheen
    Add 1 part of acid to 5 parts of water.
    Efflouresence is a known issue with grout and mortar caused by impurities in the mix. Manufacturers try to avoid it, but it still happens occasionally. It can happen fairly quickly while the grout/mortar is curing and can also occur far more slowly after curing is complete.
    30,421
    Rubber gloves and a kitchen scrubber sponge (synthetic)....one side of the sponge has an abrasive plastic layer on it.
    Depending on what the sponge is made of, the acid may slowly eat it........small price to get your tile clean.
    To repeat, if 5:1 ratio doesn't causing foaming on the material you're trying to remove, you need to strengthen the ratio until it does.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Why the gloves??
    Luv& Luk
    -Ted
