Results 1 to 9 of 9
Thread: Did the Duoclear Nature 2 cartridge change?
    My aunt has a Duoclear 35 system & has been changing her mineral cartridges as they say to. She has been getting them online with no problem. But the latest one she got looks different at the top. All the previous ones have been a yellow top that sort of looks like a hat. This latest one has a top that's gray & has no domed top. It has 4 prongs along the edge but is not like the electrode where the prongs are inside the top. The new cartridge looks identical to the old one except for the top. There is a code on the bottom of the thing W17020REV8 or B (can't tell about that last digit). Has anyone any idea what she got- is it a new design or a defective made one.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Did the Duoclear Nature 2 cartridge change?
    No idea, but generally we don't recommend using the Nature2 or any other mineral system. They put metals into the water which can cause staining.
    Welcome to TFP!
    The shape of the top shouldn't matter as long as it fits properly in the unit.
    Thanks for the replies. She sent me a picture & it looks like there are tabs on the top of the cartridge. It could be that when they made them the tabs didn't snap off because without the tabs it looks ok. Anyway, Zodiac is sedning her a replacement cartridge & a return shipping label for the weird one. That will be easier for her than figuring out what was going on with the one she had.
    As for not using the Nature 2 cartridge, how does the system work without it? I thought the mineral cartridge & salt worked with the electrode to make the chlorine. I have had some slight staining issues so I'd be interested in hearing other experiences & what changes you made.
    Thanks!
    The mineral cartridge and the SWG side have nothing to do with each other. The electrodes work with salt in the water to make chlorine. The "mineral" cartridge adds copper, which is unrelated and can cause stains or green hair.
    Ok, so what is the purpose of the mineral cartridge? Seems like it is just to make Zodiac money then.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by benj
    Yup. Copper ions will inhibit algae growth while the combination of silver and copper kill pathogens, though more slowly than chlorine, so in theory would let one operate at a somewhat lower FC/CYA ratio, but at the risk of staining. Since chlorine alone can inhibit algae and quickly kill pathogens if one has an FC at the appropriate level relative to the CYA level, then there's really no need for metal ions, algaecides, clarifiers, or other such products in a pool.
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    Did it just get brighter in here?
    22,553
    Yep, one more light came on!
