Thread: Pool vac question
    Aug 2010
    Dallas, TX
    4,052
    Pool vac question
    Searched around and couldn't find anything...
    I do not have pressure side ports on my pool (returns can't be used - pool is 50+ years old and has no fittings) but I do have a suction side port since skimmer has been replaced sometime in the last 20 or so years. Given the size of my pool, I got a robot based on recommendations that a suction side cleaner was not going to be able to keep up. I have pretty good luck with my robot, when it's working. It's down for the second time in 6 months, and the pool has a lot of sediment I'd like to get cleaned up (see my post about my sand filter failure for more info on that). Anyway, we've been trying to brush the sediment down to the main drain, but for the most part it just makes a big dust cloud in the pool and settles back down overnight. So instead of just brushing, I'd like to get a suction side vacuum and get this stuff cleaned up. Any suggestions on a style or brand of pool vac that'll work well for me? I have a 2hp pump, forget the brand, but it is plenty strong.
    Also, I am guessing that the vac is not to be used for cleaning up leaves, I need to keep using my leaf eater for those duties, right?
    Re: Pool vac question
    Correct, you don't want to vacuum up very many leaves. One or two leaves here or there is fine.
    Everyone says good things about The Pool Cleaner.
    Aug 2010
    Dallas, TX
    4,052
    To me that's more of a total pool cleaner. I'm just looking for something inexpensive to go on the end of a pole to clean up my sand mess. I'll probably use it during high pollen times too, the robot doesn't do such a good job on super fine stuff.
    For a large pool you might want to look at the professional vacuum heads, something like this one. I'm not sure if it is worth it for you, but they are easier to use than the less expensive ones.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,572
    So just get a vac head and hose for the pole then? Or check into the hayward Wanda the Whale auto one.. 120 bucks or so for automation.
    Aug 2010
    Dallas, TX
    4,052
    Perfect, that answered both my questions. Thanks again!
