Thread: Fill water #s in Louisiana
    First test with wal mart tester waiting on the tf100 I was able test Cl that was -.5 next was Ta based on 35drops to turn pinkish puts me at 350ppm turn darker took up to 50drops that's over 500ppm and obviously cya at 0 . So I need a starting point from here , I've got a 15,100 gal pool and lots of BBB supplies to start , and suggestions ? the pump should be turned on in the next hour or two Based on our neighbors usage !
    Thanks for the help ahead of time .
    18'x33'x52" AGP / recessed w/ Hayward 1.5 hp &150 gpm Hayward Extreme cartridge filter , wide mouth skimmer . TF100 test kit.
    Breaux Bridge La.
    Re: Fill water #s in Louisiana
    Have you tried doing the TA test wiping the tip of the dropper with a damp tissue after every couple of drops? Sometimes static electricity on the dropper tip can cause false high readings.
    You add drops till the sample turns something in the red/pink family, then you continue adding drops as long as each individual drop continues changing the color. The first drop that doesn't change the color any further ends the test and does not count. So TA is more like 350, and not 500.
    Yes I did wipe the tip after each drop so as you said I am inthe 350 range , as this" test kit " says turns red the do the math , though as soon as I saw complete pink I did the math. This sparkly blue water now has the green hue since it has been almost 4 days filling this rascal and the rain has not helped , but glad it waited to start after I finished construction.
    Breaux Bridge La.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    What part of Louisiana are you in and where does your fill water come from?
    Ike
    Breaux bridge area , and from Paul Simon's song Cecilia !
    Breaux Bridge La.
    Jan 2010
    Central Valley, CA
    233
    Welcome! Formerly from Bayou Chicot (Evangeline Parish) but now globe trotting thanks to the Navy.
    Garden Leisure Voyager 12x24 AGP, 7500 Gallons, Hayward Power Flo Matrix 1 HP pump, dual speed, Hayward XStream Cartridge Filter, 120 GPM,
