Solar Covers - Above Ground vs Inground
Apr 14, 2011
65
The Bluegrass State
I have an in ground pool and am looking for a solar cover. I found this one that is close enough to my size but it says in the description that it's an above ground type. I can't for the life of me figure out how there could be two types but i bet somewhere here can help me.
Also, should the cover fit PERFECTLY or can it have some space between the cover and the walls?
If you are looking for a clear cover, that should be fine. having some space is OK, but not optimal. That said it should be just fine and there is no difference, IG vs AGP.
