Thread: Solar Covers - Above Ground vs Inground
    Apr 2011
    The Bluegrass State
    61
    I have an in ground pool and am looking for a solar cover. I found this one that is close enough to my size but it says in the description that it's an above ground type. I can't for the life of me figure out how there could be two types but i bet somewhere here can help me.
    Also, should the cover fit PERFECTLY or can it have some space between the cover and the walls?
    All I know about my pool at this point:
    Size: 17,000 Gallons - Oval
    Type: Inground - Vinyl - Salt Water
    Filter: Sand
    Controller: Autopilot
    Pump: 1HP Waterway Mustang - Single Speed (MUSTS-110)
    Heater: Aquacal Heat Wave
    Robot: Barracuda G4
    Apr 2011
    The Bluegrass State
    61
    Re: Solar Covers - Above Ground vs Inground
    Forgot the link....
    http://amzn.to/lRiCpx
    Filter: Sand
    Robot: Barracuda G4
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    If you are looking for a clear cover, that should be fine. having some space is OK, but not optimal. That said it should be just fine and there is no difference, IG vs AGP.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Just make sure it's bigger and you can trim it to fit perfectly.
