Results 1 to 13 of 13
Thread: TF100 Test Kit In
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    TF100 Test Kit In
    Ok guys, test kit is in. Now I can get down to business! Lots of rain this week hardness is all out of wack! Here are the results
    FC 6
    CC 0
    TC 6
    PH 7.6
    TA 180
    CH 530
    CYA 100
    If I lower my PH to 7.0 and run the waterfall will I be able to lower it to 70??
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: TF100 Test Kit In
    My biggest concern at the moment would be the CYA of 100, as this may be much higher, try retesting after diulting the sample 50/50 with tap water then mulitply your result by 2.
    Ike
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Ditto...
    After your CYA is lowered to at least 80 we can worry about TA, but you got it right...reducing PH with acid to 7.0 will also reduce TA some. You then aerate to increase PH without raising TA. Repeat if needed.
    The main issue in those results is that FC of 6 with CYA at 100 is too low.
    30,419
    Double ditto! Reducing CYA with a partial drain will likely reduce your CH at the same time. Then deal with pH and TA.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Draining water right now!
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Will a partial water change lower my TA also?
    Water replacement is very likely to lower TA, CH, and CYA. However, there will be some TA and CH in the fill water, so they won't go down as much as CYA does. To find out how much of an effect that is you need to test your fill water TA and CH levels. Fill water never has CYA in it.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Thanks Jason. Drained out 30" of water, refilling now.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Ok after the filter ran today here are the results:
    FC 2.5
    TC 2.5
    CC 0
    PH 7.2 Maybe 7.0 hard to tell
    TA 120
    CH 410
    CYA 85
    Much better!
    Time to raise the FC level up to the 7-12 range. PH should drift up on it's own.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Jason I put 1.5 gallons of Bleach in to raise it up to seven, is it safe to say I can go ahead and shock it?
    Yes, if you need to shock, go right ahead. Shocking with CYA at 85 will be a little challenging, but still way way better than shocking with CYA at 100+. SInce you have a SWG, it is probably worth the hassle of shocking with CYA that high, rather than more draining and then having to raise CYA back up.
    Nothing in this topic suggested a need to shock, so I didn't mention it. If there water is clear and FC holds there is no need to shock. I have forgotten your other topics by now (Sorry, I read so much around here) so I've lost the context of what you were doing. That is one of the reasons it is nice if you keep everything relating to a single project together in one place.
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Sorry Jason, I shouldn't have started a new thread. I'm getting some spots of algae forming thats when this whole CYA thing started. But I was holding off until I got the TF100 kit to shock and do borates.
