Thread: Autopilot SC-36 Cell electric cord question
    Hi,
    I got a replacement cord for the SC-36 autopilot cell. The cord has 3 holes but the cell has 2 pins... Which ones are the right holes for the 2 pins of the cell?
    Thanks
    Ft Lauderdale, Florida
    1,455
    Re: Autopilot SC-36 Cell electric cord question
    It does not matter. The center hole is one polarity, while the two outer holes are spliced together. However, the opened hole should have a red cap inserted from the factory, so as to prevent water or moisture from entering and shorting out the cell plug.
    If no cap is available, you can use a gob of silicone to block it off.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
