Thread: Advice needed: Foam on staris and swimout or not?
    Hey folks,
    If you are following my construction thread you already know that my PB decided to proactively replace the initial liner for quality reasons
    But in checking out the currently installed liner I noticed that there is no foam padding on the swim-out bottom or on any of the stair treads. I have been in pools that have foam and have found them comfortable. I asked him why not and he said that the soft surface is more prone to puncture, especially since these are high traffic/kid areas. He also said that he would do it if I wanted it.
    What is the general consensus on this topic?
    Thanks in advance!
    16 x 42 x 24 IG Vinyl True-L, 27,000 gallons, full width steel steps, 8' Cuddle cove swimout, 2 X Colorlogic 4.0 LEDs, Hayward Tristar 1 hp 2-speed pump, Hayward SwimClear C3025 Cartridge filter, Hayward Aqua-Plus PL-PLUS Controls + Chlorination, Hayward low-Nox 400K BTU heater, Tigershark QC, TF-100 test kit
    Re: Advice needed: Foam on staris and swimout or not?
    Bumping this ... I need to make a decision before tomorrow!!!!
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I have had foam on my steps and swim out step for 5 seasons and have had no issues.
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    Dec 2009
    Central Massachusetts
    2,690
    I dont have foam on my stairs for that reason. Made sense not too since the bottom doesnt have foam. But, i dunno, it could be ok.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
