Thread: NEW AQUACAL HEAT PUMP - WIRING QUESTION
    So, the short story is that my wife and I purchased a bank-owned home, and the prior owner removed the heat pump prior to moving out (among other things)
    So, we just had a new AquaCal Heatwave 120 installed and my electrician came out today to take a look at the set up. Mind you last year, we put just a switch on the side of our filter to turn the pool filter on and off - no time clock, nothing.
    So, I need to find out the proper way to wire everything together with a time clock. I do not need an automated system as I do not intend to run a salt-chlorination (also removed from the home) and our Pool light is actually hard wired into our kitchen.
    Please let me know what you would recommend as to whether there is a certain time clock for wiring the heat pump and the Hayward Pool Filter.
    24,000 18 x 36 IG vinyl. Hayward S-244T sand filter( up to 52 GPM flow rate) w/ EZ Flo 3/4 HP 1.0 SF
    Dec 2009
    Central Massachusetts
    2,690
    Re: NEW AQUACAL HEAT PUMP - WIRING QUESTION
    A simple intermatic timer can be used for the filter pump.
    As for the heat pump, that doesnt need to be on a timer. Once the filter pump shuts off, the heater will shut itself down since there is no water flow though the heater. When the filter pump comes back on, the heater will start again if the water temp is below the set point of the heater.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Welcome to TFP!
    The best thing to do is to get a timer with a fireman switch, like the Intermatic T104P201, and then wire the fireman switch to the heat pump so the heat pump won't come on when the pump is off. You don't have to do it this way, since the heat pump can tell when the pump is off. However, the flow detection switch in the heat pump isn't 100% reliable, so it is better if the timer tells the heat pump when to turn off just to be sure.
    Dec 2009
    2,690
    Welcome to TFP!
    Belt and suspenders I suppose.
    Ft Lauderdale, Florida
    1,455
    AquaCal uses a pressure switch to ensure the heat pump does not come on when the pump is off. Even if it did, the lack of flow would cause the low or high pressure condition of the refrigerant to shut it down.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
