Thread: Rebuild vs replace diverter valves
    Greetings,
    I expect to be doing a bit of plumbing for my filter/pump swap. However, I'd prefer to preserve as much of the original plumbing as is prudent. I have several Jandy 3way diverter values w/grease fittings in the mix; does it make sense to try and rebuild/refurbish these or simply replace them?
    34 x 19 salt water free form. 7.5" inside diameter raised spa. 24" raised beam in back. 3 moss rock waterfalls off raised beam and moss rock waterfall out of the spa. (2) Intelliflo VF pumps, 420 Cartridge Filter, 400 BTU Pentair low nox heater. 2.5" suction and 2" returns throughout.
    Re: Rebuild vs replace diverter valves
    With proper maintenance those valves will last nearly forever. Or they make a retrofit kit that will transform them into never lube valves. I wouldn't replace the valve body unless there was some reason to tear out that section of plumbing or there was something obviously wrong with it.
