Thread: Another Happy LQ Customer
    Apr 2011
    South Point, Ohio
    32
    Received my new LQ today ... install took at the most 35 minuets counting the unboxing and direction reading. No leaks on any of the lines and i have enough pressure from my pump to max the flow meter out. I have a chemical levels baseline to start with and have adjusted my flow to be in between one and two on the meter since the pool water is still 60 degrees and not being used yet. Once the weather warms up i figure i can adjust for more flow as needed. i decided not to use one of the inline check valves as my LQ and pump is above water level and i was holding a prime when the pump was shut off. Again thanks to everyone for the help and advise with the LQ.
    24' Round Above Ground
    15,000 Gallons
    Hayward Pro Series 100 Lbs Sand Filter
    Hayward Power Flo LX 1hp Pump
    8 gallon Liquidator 3/8
    BBB Method
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Another Happy LQ Customer
    Is that with the 3/8 uprade stuff? Where'd you get it btw. Nice looking setup.
    Apr 2011
    South Point, Ohio
    32
    Yes it has the 3/8 upgrade. I got it from pst pool supplies.
    15,000 Gallons
    BBB Method
