Thread: The Black Algae was in my pool!
    Black algae showed up last year... It depressed me. I scrubbed at it some and was sad. This spring I had had about 50 times the spots from the year before. Instead of sad, I got mad and thought I might try to actually do something about it.
    A little background. The Ph in my pool loves to sit at 8.0. I got tired of the constant addition od MA over the winter so I let it go to 8 and stay. This spring, in preparation for swimming temps, I lowered the Ph and had these numbers
    FC 1
    TC 1
    Ph 7.2
    TA 70
    CH 300
    CYA ZERO.
    So, I added enough stabilizer to get CYA to 40 and kept the pump running 24-7. 2 days later, I donned the scuba gear and grabbed a pumice stone. It took about an hour but I swear I scrubbed the heads off every spot. Of course the roots were still quite visible. I got out and checked Ph and CYA. CYA was up to 40 and guess what! the Ph was still at 7.5. Last year it would have been back up to 7.9-8.0. I guess it took my plaster 2.5 years to cure...
    Here comes the Shock. I dropped in 3 2.5 gal carboys of CL from ace hardware and another that I had left over from last year. About 4 hours later, at sunset, I checked CL and had:
    FC 32.5
    TC 34
    CC 1.5
    Not a single spot is visible anywhere in the pool! I brushed all the walls down anyway with a SS brush with the fin on the back that really forces the bristles against the pool walls.
    Today, things still look great. I did not do an overnight test, I'll do that tonight. The guys at the pool store wanted to sell me some algaecide but I wanted to try elbow grease first.
    I am no longer sad or mad.
    22,000 Gunite, Cart Filter, Aquarite SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: The Black Algae was in my pool!
    Good for you!
    That ultra-shock may not be such a bad thing....who knows if there was any of that algae, say, behind the light? I'd keep the wire brush handy anyway.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Cool. Sounds like you got it.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Uh, just keep brushing. The brushing keeps the heads knocked off and doing so for a couple of weeks will ensure the chlorine kills every speck of root left. Once is not enough. Brush daily for several days while at shock level.
    Great job - your gonna be pleased to have killed the beast
    And they said black algae is like herpes!
    I forgot to add that after I got the CL in the pool, I set the Polaris loose to pick up all the heads laying on the pool bottom. They went into the trash that night. With the cart filter (with new elements added last month) I did not want to vac them.
    I hope if you read this after you found black algae in your pool and did a search on what to do, you won't get sad, or mad... It is just a minor problem that has a fix. Scrub and shock and brush, no big deal!
    I'd write more but I gotta brush my pool!
    11,969
    My only regret is that you did not post before and after pics! We have so many people who don't know what BA looks like and they think they have it and it turns out to be something else entirely....
