Results 1 to 8 of 8
Thread: Pool supplies on hand
    Nov 2010
    South Central Kentucky
    283
    I thought I'd ask what "chemicals" you all keep on hand that you use frequently throughout the pool season.
    I have an SWG pool, so if you have info more specific to that application it would be helpful.
    Right now I have:
    A few 182 oz. bottles of bleach
    2 - 4 lb bottles of CYA granules
    1 - 12 lb bag of baking soda
    I'm assuming, once I'm up and going, I will be needing salt. How much of that should I keep on hand?
    Anything else I should have available?
    15x32 vinyl liner, 14,400 gal, 1.4hp Centurion pump, 3/4 hp booster pump, Hayward Pro Series S244T Sand Filter, Hayward H200 heater (digital readout)
    Aqua Rite Electronic Chlorine Generator, Hayward Phantom cleaner, TF 100 test kit
    Pool School, Pool Calculator
    22,553
    Re: Pool supplies on hand
    Not having an swcg pool I keep several bottles of bleach on hand as well as a jug of muratic acid. Oh yeah, and a killer of a test kit!
    I don't usually need anything else. If I need anything else, I just wait till next time out and pic it up. The only thing that can be an emergency would be running out of bleach so I keep a few jugs on hand besides what's in the tank.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I also don't have an SWG, but a lot depends on the individual pool, if pH tends to drift with time, how fast and if that is up or down. Having said that I chlorinate with bleach, but also keep some stabilizer on hand as well as some dry acid, a couple of pounds of dichlor shock for those occasional needs to quickly boost chlorine levels (since CYA goes down over time due to splash out etc I like having the option to raise both). I also keep a few things specific to my needs like some MPS shock on hand, but this is due to having an indoor pool.
    Ike
    30,431
    Double ditto what bama just said. Once you get tuned in, you don't need much but chlorine (and I would suggest a jug or two even with your SWG) and acid.
    Vero Beach, FL
    462
    I have a SWG and keep:
    Couple 2.5 gal jugs of chlorine in case I need a quick boost.
    Baking Soda
    Soda Ash
    Muratic acid
    CYA
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    JesseJames's Avatar
    Sep 2009
    Florida
    64
    I do not use bleach and do not buy chlorine.
    Once your salt is at the proper level you will rarely need to add. So, keeping a bag or two on hand is very sufficient.
    I use about one quart of muratic acid every five days and a couple of pounds of baking soda once in a while. I also add a little CYA in the early Spring. You really do not need a lot of supplies.
    13K Gal., Plaster, SWG, Intellichlor IC 20, Sta-Rite 1 HP Pump, Sta-Rite PLM 300 Filter, Pentair LED, Solar, Screened Enclosure, Great White, TF-100
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Quote Originally Posted by JesseJames
    This is a perfect example of differences in local conditions, I have not used more than a quart of acid in the last year.
    Ike
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    I keep a case of bleach and a case of acid. That's how it comes, 4 refillable jugs in a plastic crate. Sometimes it ends up 3/5 or 2/6, but I always have a week or more.
    I worry more about keeping test kit reagents on hand. Bleach, acid, baking soda, and salt are all readily available. You're not likely to have a sudden demand for CYA. But in the height of pool season, good luck finding any test kit refills in a store, besides maybe pH. And good luck finding refills for the FAS-DPD test any time of year!
