Thread: Where to find a structural engineer for permit
    Feb 2011
    Sicklerville, NJ
    80
    I've called the few listed in the yellow pages for my area, nobody calls back. Submitted a request on ServiceMagic... got exactly 1 call back and they don't do this type of pool? I just need a NJ licensed engineer to approve my pool plan to get the construction permit. It's a regular vinyl liner pool like thousands of others going into a wide open, flat yard. Does anyone know where to look or have some other suggestion? Already approved for zoning and the kit is on the way.
    25k gal Lazy-L, vinyl liner, poly walls, swimout spa, diving board, TurboTwister slide.
    Hayward 2HP 2-spd pump, Pentair 2HP spa pump, Hayward 30" 500lb sand filter.
    Goldline Pro Logic PS-8 automation/SWG. 2 LED ColorLogic 4.0. 8 Jandy deck jets. MX-8 cleaner.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Where to find a structural engineer for permit
    Not all engineering firms are accepted by the building department so you might ask the city what other pool builders use.
    Mark
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You might look under Land Surveyors. Larger companies usually have civil engineers on staff, and often have engineering in the business name.
    These are businesses that are more used to dealing with individuals, so you may get a better response.
    Lehigh Valley, Pennsylvania
    71
    You need a civil engineer, not necessarily a structural engineer. Depending on what the Township requires, you may need a lot grading plan prepared. Relatively small job, that's why slow call backs. Ask your Township building officials or pool builder. They can probably give you some names.
    25K gal vinyl inground, 1HP Hayward Pump, Hayward DE 4820 Filter
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Ask the permit office guy face to face... he probably wont give out a reference over the phone coz they arent supposed to... but if he sees the crazed desperation in your eyes he may take pity on you. Or ask to see some other "example" structural permits filed and get the names off of those!
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Feb 2011
    Sicklerville, NJ
    80
    Quote Originally Posted by JohnT
    You might look under Land Surveyors. Larger companies usually have civil engineers on staff, and often have engineering in the business name. These are businesses that are more used to dealing with individuals, so you may get a better response.
    Good idea, hadn't thought of that as I was stuck on the structural aspect. A smaller company did call me back and was of help. I guess I was freaking out because it took so long and thought I was just getting brushed off.
    Quote Originally Posted by Rob621
    The town gave me a waiver to sign that I wasn't significantly changing the grade, s I shouldn't need a grading plan. There is a size limit that my pool is just at so I'm crossing my fingers this won't be an issue.
    Quote Originally Posted by Lershac
    They're always very official with me and, like you said, gave me the "can't give references" reply previously. They're very friendly and talkative to my wife when she goes in, though. If needed I could send her in to something out of them.
