Page 1 of 2 12 LastLast
Results 1 to 20 of 29
Thread: New pool owner checking in with numbers
    I have been over at the build section now water is in and will be here also. For starters I have ordered the T100 test kit. Had pool store run my numbers yesterday and then again this morning to see were I am at after putting the chems in.
    This AM
    FC 5.0
    PH 7.4
    TA 150
    CH 250
    CYA 60
    SALT 3500
    The pool guy said all was good except TA and compared to TFP it agrees. He looked at me crazy eyed when I questioned a lower then 80 CYA.
    I Have a sand filter with Zeo Bright in it. My water is still cloudy do I need to give it more time to pump to start clearing up.
    Pool is 37000 gallons using a Aqua plus. What should I start my percentage at?
    Im hoping by friday my test kit will be here and I can play mad scientists.
    Thanks
    Buck
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    2 HP Hayward Super Pump with 25" Sand Filter Filled with Zeo Bright
    4 Pentair Deck Jets
    2 Hayward ColorLogic 4.0 Lights
    Diving Board
    Turbo Twister Slide
    Hayward Aqua Plus Automation with 2 Actuators
    100% DIY Build not 1 penny paid yet to build this thing!!!! = Lots of work and Long Nights
    Re: New pool owner checking in with numbers
    any ideas why my pool is still cloudy?
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Numbers look pretty good...except for TA, but that's not such a big concern right now. Just make sure to adjust it down before it gets to 7.8 or above.
    The cloudiness could be from the initial fill and it could just take the sand filter a few days to filter out. Was it initiall clear and then went cloudy or was it cloudy since filling? What is the source of your fill water?
    30,419
    Give us a little more info. Did it start out cloudy? What is your fill source? Help us with the background info and we can help answer your question better.
    What state are you located in?
    Im in south alabama. Water temp is around 81 already. Water was city water. Was clear and clouded up as soon as I turned the pump on friday.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Aug 2010
    Dallas, TX
    4,052
    did you do a good backflush before putting the valve in the "clean" position?
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Quote Originally Posted by RobbieH
    Perhaps the Zeobrite? Good point
    30,419
    If it started clear and you didn't backwash, then I would think it to be the zeobrite as well.
    I did not do a good backwash. What's that mean now?
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Fresh zeo releases a lot of dust. Normally you backwash it for 10 minutes before using it for the very first time. I would do a five minute backwash right now. Over time the dust in the pool will either settle or get filtered out.
    Ok guess I created alot more work for myself. Would it be a good assumption to do a long back wash rinse cycle then run filter for 1 turn over and start again until it clears up. Should I wait between cycles to start over so stuff can can settle then vacuum. Can I add anything to the water to help collect up the small particles.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    DE and Zeobright
    Can I add DE with zeo bright in filter. Will this help with clearing up the water. I failed to backwash after putting zeo in now I have a cloudy blue pool.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Re: DE and Zeobright
    You can add a little DE to a sand filter with zeo in it, and it will help clear up the water to some extent. However, it won't stop zeo dust that is already in the filter from coming out if you haven't completely backwashed the filter yet.
    I will do a intense backwash here in a bit. Leaving work and was going to grab some DE. Run the filter tonight and do it all over again in the morning. Do I look for the 1psi rise like a sand filled filter?
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Now that I am working a lot with my multiport doing alot of backwashing...Is it normal or what would cause it to sound like there is sand ticking sound coming from it. My pump basket does not appear to have any air bubbles visible. The PSI is reading 15psi after a intense backwash, is this a normal number.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    Just got my test kit in and ran a test.
    TC orange color not on chart
    PH 7.4
    CYA 80
    TA 110
    CH 280
    FC 23
    CC No change in color so I assume less then .5
    How long will fc take to get in normal range after shocking it. I shocked last friday but have ran pump 24/7 to get rid of cloudy mess from zeobrite. SWG has been on this whole time at 60%. Do I need to turn off swg or lower out put to bring down fc.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
    30,419
    Day before yesterday you reported FC of 5 and now it's 23. Did you add FC or was the pool store that far off? If you added, why?
    Keep us informed as to what steps you take to get your pool cleared . Have you backwashed yet? That would be my first priority.
    15 psi sounds about right. How high do you let it get before you backwash?
    Have you added the DE? Yes, a 1psi rise should be ebough.
    WIth CYA at 80, it will be several days before FC is down to a more normal level.
    I did not add any new chlorine other then what SWG is making, should I lower the swg %. I have backwashed 2 times so far. Would it do any good to add any product to help cleaning it out. When it would raise 4-5 psi I would backwash.
    Appx 37000 Gallons
    IG Pool
    vinyl Liner
    4 Pentair Deck Jets
    Diving Board
    Turbo Twister Slide
  20. Back To Top    #20
    As long as there is no reason to keep shocking, you should turn the SWG off entirely for a couple of days, while keeping an eye on the FC level, until FC comes down to something more reasonable.
