I think I found a leak
rxman
May 30, 2008
63
I have been losing water from my pool. I think this could be the source of my problems. I have attached pictures. This is of a leaf/debris canister. In the gap between the two plastic pieces is concrete as well as dirt. Yes, dirt!
How do I fix something like this?
I would suggest powering out the dirt with a power nozzle on a water hose. Any remaining dirt, use a knife blade to remove. Allow to dry. Wipe the crack out with alcohol and allow to dry. Fill the crack with silicon.
I'm sorry. I'm not sure how or even if it has shifted right or left. The gap (as far as the width) has been there since day one. My coping is very thick and with the deck poured there was a gap there. The gap has some concrete. I think it was supposed to be filled in smooth but wasn't. I really don't know.
That is just a "Beauty ring", basically a filler above the leaf basket.
Your pool water should never get above the lid you see below, so that should not be an issue.
You can certainly clean out some of the dirt and run a bead of silicone to keep it clean.
