Thread: Thank You TFP
    Apr 2010
    East KY
    51
    Thank You TFP
    I found this site last year after I bought a foreclosure with a neglected pool monster. The cover was half in half out of the blackish green murky mess, after the Pool Store giving me the run around and obviously not knowing what they were talking about I went in search of more knowledge and I land here at TFP. With your help and armed with the knowledge I gained from Pool School I was able to get it to a dull cloudy look before I made a hole in the liner. Once the liner was changed, I followed the BBB method and am happy to report no major issues all last year and the cost of maintaining the pool was almost insignificant.
    Now comes opening up this year. Yesterday I pumped all the remaining water from the cover. Then I began to loosen the cable and I got a peak at the water underneath. I'm here to tell you, it was a beautiful site. The water was as clear as when I closed at the end of last year. I was shocked how clean it was, and all I did was follow the closing advice here on the forum. I hooked up all the plumbing and started filling it last night. I got up this morning to a full pool and turned on the pump, everything worked as it should.
    I can't believe how easy this opening is going to be, thanks to TFP. I was expecting a lot more work based on my experience last year.
    11400 Gallon AG 22ft
    Hayward Sand Filter
    1 HP Hayward XL Pump
    Liquidator 3/8" upgrade, Hayward Needle Valve
    Useful Links: Turning Your Green Swamp Back into a Sparkling Oasis, Pool School, The Pool Calculator
    crookm11's Avatar
    Jun 2010
    Copperas Cove, Texas
    422
    Re: Thank You TFP
    Congrats on the POOL!!
    Mark Crook
    13,500 Gallon 24' x 52" Intex Ultra Frame
    Intex Sand Filter and Pump, Intex SWG (All hard PVC plumbed)
    TFTestKit-100---Pool School---The Pool Calculator
    Location: Copperas Cove, Texas --- My Pool Build---Useful Links for Intex Pool Owners
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Thank You TFP
    I know what you mean! The Spring of 2008 when I opened my clear pool for the FIRST TIME EVER, and it still had FC from the Fall. I was stunned and I shouldn't have been surprised at all. This forum rocks.
    mikespoolfl's Avatar
    Mar 2011
    Florida
    179
    Re: Thank You TFP
    Have to agree, I'm putting less junk in my pool and it looks better than ever. It’s amazing what you can achieve using a good test kit and the folks on here.
    I have the TF 100 with the speed stir. You can't go wrong with good numbers.
    Screen enclosed 17K gal 16x30 IG with Diamond Brite finish, elevated 4 jet spa with spill over, Twin dolphin fountain, Hayward Ecostar pump[ Pentair intelliflo VS, Filter Sta rite Posi-Flo PTM 100, Aqua Cal heat pump, Tiger Shark QC robotic cleaner.
    Stenner peristaltic pump model 45MPHP10, 15 gal storage tank. TF 100 with Speed Stir.
