Thread: anything special about a booster pump?
    Is there anything special about a booster pump, or could I just use a dedicated 3/4hp pump, or even a 3050vs? Thanks
    In ground Pool and spa Specification
    Free form
    18000 Gallons
    7 person spa¬*
    Tr100 Sand filter
    Pacific Blue Hydrozo plaster
    1 3050VS for pool and spa¬*
    Raypac 400btu
    Polairs 280 with booster pump
    Inteli touch automation¬*
    3 Pentair LED's
    Re: anything special about a booster pump?
    Booster pumps produce a high pressure low flow stream of water. A normal pool pump is designed to produce low pressure high flow. If you pool cleaner is designed to work with a booster pump it is very unlikely to work with a pool pump. There are other pool cleaners designed to work with a regular pool pump.
