Results 1 to 10 of 10
Thread: Its that time again!
    Jun 2007
    Kernersville, NC
    45
    Well i have taken off the cover to a nice green mess. My last pool opening went like clock work, but this year is starting off on the wrong foot. I guess through one of the nasty storms here in NC, my cover had a hole put in it and it looks like I took some leaves in. The pool is really green so I took my readings.
    FC 1.5
    CC 0
    TC 1.5
    PH 6.8
    T/A 20
    CH 40
    CYA 0
    Please HELP. My sons b day party is this weekend. I don't care to swim in it but I would like it to be presentable.
    AGP (Wil-Par): 24' round, approx 14,000 gallon, 2 hp- 2 speed cartridge filter, TF100 test kit.
    Re: Its that time again!
    First, raise the TA to around 70. Then test the PH again, and adjust from where it is then to around 7.4.
    Meanwhile, start raising CYA up to around 40.
    Then start shocking the pool.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    was the water circulating before you tested, at least 12-24 hours?
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    If TA is below 50 do TA first, Then If PH is completely out of range fix that, unless FC is above 10 in which case you ignore it. Then FC, then PH, CYA, then TA. What to add is in pool school. How much to add is the pool calculator there.
    Jun 2007
    Kernersville, NC
    45
    I started the pump today at about 5:00pm. It has been running since.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Don't expect miracles, but with a bit of work you should be able to make it more presentable by next weekend. The sooner you start the better though, the the pH in the right ballpark first, add enough CYA to get it in range (use the sock method), then assume your at your target CYA as it can take a week or more to show up on tests. You can use dichlor shock for initial shocking as it will also raise CYA, or keep it separate and use stabilizer and liquid chlorine/bleach. The key here is maintain shock level, test and add chlorine as needed every couple of hours in the beginning, it will hold longer and longer as you go along. Scrub, scoop out leaves, vacuum and clean your filter often.
    Ike
    11,969
    Quote Originally Posted by jerzeyrep01
    sometimes you see different test results after the water has been circulating, that's why I asked that. Be sure to retest before you start treating with chems.
    Isaac is right - hit it hard. I cleared a green pool in 2 1/2 days last May. The PO couldn't believe it, in the past, it would take him weeks following pool store advice. He's now a BBB believer....
    Jun 2007
    Kernersville, NC
    45
    thanks guys. I added my stabilizer, and stopped at walmart for 4 182oz jugs, says i need to add 280 to start. i have already set my auto vac up and has been running for about 5 hours. i will wait for the sun to go down and then begin my assault on the algae ..I have some let over tabs, should i add them too tonight to make sure i maintain my levels. i will stay up until midnight to do my last check.
    Mar 2009
    Charlotte, NC
    539
    Get plenty more bleach. If you don't need it for this shocking process no worries you'll use it soon enough.
    Once you start shocking you re-test the FC every hr if possible.
    If you added stabilizer then no need for the tabs
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Jun 2007
    Kernersville, NC
    45
    Just wanted to come on and say THANK YOU, to everyone's input and for all of your help. After opening to a green swamp I am proud to say that my pool is sparkling clean and ready to swim in just 4 days. My sons second bday party is tomorrow and the pool looks great. All I can say is if anyone doubts the methods and recommendations of this site and the peeps that inhabit it, they are crazy. This is my 4th year with the TFP system and my pool is immaculate.
