Results 1 to 8 of 8
Thread: Taylor K-2006 Test Kit
    I have the Taylor K-2006 test kit and I am wondering if anyone has any tips for reading the pH? The color variations on the vial are so similar it is hard to tell the difference between them. Is it easier to read in sunlight? Against a white background? Any tips would be appreciated.
    Princeton, WV
    Intex Ultra Frame - 12 x 24 AGP
    Intex SWG and Intex Filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Taylor K-2006 Test Kit
    about one inch from a white background. Bright light is best, sunlight if possible.
    Thanks, I will have to try that. I have been testing the water in the house so I can have the counter available. I guess when I get to the pH test, I will take it outside. Thanks again!
    Princeton, WV
    Jul 2010
    Pt. Arthur, TX
    174
    The color seems easier to discern with my blue pool water in the background.
    But I think I'm color blind.
    Custom Cloud shaped 19'x35' - Raised Spa 6' diameter
    Rainbow 320 Inline Chlorinator - Paramount Clear O3 Ozone Generator
    Hayward C4025 Cartridge Filter (Hayward CX880XRE) - Hayward Tristar 2 speed pump
    Hayward H400Fdn Heater, Hayward GVA-24 (valve actuators)
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    A couple things:
    1) White background. I have some cheap plastic patio chairs that work good for that.
    2) I hold the tester at arm's length. Sometimes I squint a little, so it all gets blurry, and the numbers aren't legible. For some reason, it helps. I can tell if it's closer to 7.2 or 7.5 that way - good to .1.
    Jan 2009
    Cupertino, CA
    1,966
    Don't look at the yellow OTO test first; it will change your perception of orange hues. Read pH first.
    --paulr
    BBB "Intermediate Swimmer"
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Remember also your looking for color/hue not intensity/saturation
    Ike
    Mar 2009
    Huntsville, AL
    156
    It seems easier when I compare one color block at a time. Pick three adjacent color blocks that look close and cover the top and bottoms one with your fingers (I make a "V" with my index and middle fingers and use them to make a slot). Look at the middle color block and see if the sample matches it. Move your fingers up and down the color blocks until you find the matching shade.
    27K gal, IG vinyl, 1.5 HP pump, 24" sand filter, Goldline Aqua Plus SWG
